93 del sol - trying to replace the trunk/gas release lever
Old Apr 19, 2016 | 09:08 AM
Roosterjd's Avatar
Default 93 del sol - trying to replace the trunk/gas release lever
So, I'm trying to replace the Trunk/gas release lever on my 93 del sol. (To provide an interior trunk release)
Got the mechanism from a 97 body...check
Removed the old (and new) inside release mechanism. They fit. Check
Having trouble finding a cable ,so I went to look at the attachment on the trunk latch. I figured worst case I could have one fabricated.
PROBLEM!!!!
How do you remove the plastic piece on the edge of the trunk that covers the latch (and trunk carpet edge)?
There are several pop outs along the top edge of the plastic piece but there is a lot of resistance so I didn't force them too hard.
I know this is a silly question but I dont want to break anything I can avoid.
Thanks for the answers...and your patience!
Jim
Old Apr 19, 2016 | 09:59 AM
tony_2018's Avatar
Fish Twig
Default re: 93 del sol - trying to replace the trunk/gas release lever
Dude....I need pics to see what you are even talking about.
I'm sure the del sol never came with a trunk release and watching video's of people breaking into their own del sols made me realize why you want to do this.
Anyways.........pics.
Old Apr 19, 2016 | 10:43 AM
Nave43's Avatar
That plastic piece is riveted to the carpet, but it just pops right off the metal. Trim tools help, well worth 1.89 imho.
http://www.ebay.com/itm/281704189410?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Later model Sols did have a trunk release, 1995+ . I read somewhere (forums?) that a later model release should pretty much bolt right into a 93.
With the cables being hard to find i would do some research and find the part# of a oem release. Get the specs on it, then get one fabricated. Or just order one from majestic.
http://www.hondaautomotiveparts.com/...A5MT&catcgry5=
... i cant find it :/
Old Apr 19, 2016 | 10:48 AM
Roosterjd's Avatar
The del sol came with them...after 94 I think
Anyway, here is a pic. I need to know how the plastic piece covering the latch is removed.
The plastic piece that runs the length of the trunk
Old Apr 19, 2016 | 10:56 AM
tony_2018's Avatar
Fish Twig
A closer shot would be nice, so I can see what they really look like and how to proceed.
Worst case scenario, you'll have to break em and by cheap ones off ebay.
Old Apr 19, 2016 | 11:00 AM
Nave43's Avatar
Just remove the clips along the top edge then undue the clips holding it to the sides of the trunk carpet. Hopefully you can see all the clip holes in the pictures. See how the plastic is part of the carpet.
Squeeze from the bottom and pry from the top indent if you have one, wrap your prying devices in electrical tape or a rag to keep from messing up the interior.
Old Apr 19, 2016 | 12:11 PM
tony_2018's Avatar
Fish Twig
Well you can't really tell where to squeeze from, you say squeeze from the bottom but the bottom of what clip? How do you even get to the bottom of the clip if its inside, behind the panel?
Old Apr 19, 2016 | 12:46 PM
Roosterjd's Avatar
Thanks! I got it. The explanation and pics really helped! Now got to figure out which of these five nuts need to come off to remove the license plate panel so i can get to the latch itself!
For now though....I'm off to dinner and the theater with my bride!
Cheerio
Old Apr 19, 2016 | 10:51 PM
JarvisW's Avatar
Sol to Sol
Default Re: 93 del sol - trying to replace the trunk/gas release lever
OP Cool!
Tony, you're usually on, but some later SI Sols, and/or VTEC models came with trunk release.
My old local sol bud had one stock, and did the mod to his GFs.
you can see them, with the correct cables here...
#20, and #24 (not for my car, but you can play with the settings with newer and VTEC models to get parts)
http://www.hondaautomotiveparts.com/...gry5=TRUNK+LID
Old Apr 20, 2016 | 06:04 AM
tony_2018's Avatar
Fish Twig
Originally Posted by JarvisW
OP Cool!
Yeah I was reading up on how some people were using the latches from other makes/models and modifying it to work. Pretty neat idea if you want to lock the latch.
Old Apr 22, 2016 | 12:56 PM
Roosterjd's Avatar
So....Finally got the stupid latch off! Ended up having to drill the heads off the screws.....then could turn them out by hand once the latch was out! Aaaaargh!
Went to a local lawnmower repair shop and had a cable fabricated (for half the price of one from honda that MIGHT work. Have I mentioned that I am UNIMPRESSED with my local honda dealer?
Tomorrow I begin the reinstall! Wish me luck!
Thanks for all your help folks!
rickjames8
Dec 1, 2015 03:53 PM
KodSol
Jan 19, 2012 02:41 PM
craven160
Apr 7, 2011 12:41 PM
Sonia's Driver
Jan 19, 2011 05:37 AM
k7q
17
Jul 19, 2006 11:26 AM
