Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
Old Apr 9, 2016 | 02:00 PM
95Hatch_209's Avatar
Default Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
97 civic, automatic transmission. Replaced the radiator yesterday, and some tranny fluid came out when doing so. So i added what i thought was lost and when i started it up and put it in reverse the check engine came on along with the "D4" light blinking. the car wont go now. When i accelerate the car doesnt respond like it should. I plugged an ob2 scanner in and "P0700 & P0758" came up. Please help. :'(
Old Apr 9, 2016 | 03:52 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
did you unplug anything to get the radiator out? go and check everything is pluged in good, no grounds are disconnected and check all your fuses are good.
Old Apr 9, 2016 | 04:12 PM
Everything is plugged in correctly. Not sure about the fuses. Some tranny fluid was lost while replacing the radiator but i topped it off and checked the level and it was fine.
Old Apr 9, 2016 | 06:41 PM
Former User's Avatar
You probably accidently unplugged the shift control solenoid. It's close to where you were working.
Marco_97
Mar 3, 2011 04:57 AM
ice4me
Nov 30, 2006 01:36 PM
pinoyboiwonder
12
Feb 3, 2006 10:51 AM
nottswife
Aug 14, 2005 07:31 PM
im_the_teacher
Aug 5, 2003 11:02 PM
