Honda CR-V & Element 2WD & 4WD Element & CR-V
CRV Takata Airbag Issue
Old Apr 7, 2016 | 06:02 PM
ltrain1990's Avatar
Default CRV Takata Airbag Issue
New to the group. I have found some older threads regarding disabling airbags on the older civic's. My daughter has an 07 CRV and loves the car. Unfortunately, it is now part of the expanded recall for the inflator problem. Parts not due in until mid summer, she can't rent a car as she is not old enough. I would prefer to simply pull the plug on the airbags in her car until the parts come in and it's done. Pulled the fuse, but after reading the civic posts, maybe there's more to it. Either I can disable the airbags or tomorrow I trade it in. Any thoughts? Appreciate it.
Old Apr 7, 2016 | 06:31 PM
ltrain1990's Avatar
Default Re: CRV Takata Airbag Issue
Please disregard. I found a previous post that solved the problem. Thanks.
Old Apr 7, 2016 | 06:51 PM
LDForget's Avatar
pulling the fuse does disable them, but if you want them completely disconnected, use a flat head screw driver and flip the steering wheel upside down. theres a small access pannel that you need to remove. unclip the yellow cable and put the panel back on. open the glove box and pull it all the way down to the floor. theres a yellow cable behind where the box sits. disconnect the yellow connector.
Old Apr 7, 2016 | 07:00 PM
ltrain1990's Avatar
Roger that. Thanks much for the response!!
JimmyJoe
Mar 27, 2016 10:31 PM
Girls hair
Honda Civic (2001 - 2005)
Jan 11, 2013 06:38 PM
fatalerror
10
Apr 8, 2009 01:43 PM
Aphelion
Aug 31, 2005 10:52 PM
