D16y8 Ef swap !!
I need help figuring out what injectors I need to run on a d16y8 in a 1991 Honda Civic ex 5 speed and I wanna know if I can go straight to the mpfi swap with the y8 manifold please anything helps
No I have not pulled the motor out yet it is still the stock d15b1 no I did not get the conversion harness but Ik it's a obdo to obd1 and ik Im gonna run p28 but can I use y8 injectors I'm looking to not run a resistor box so Ik I need 92-00 injectors
anytime I search dpfi to mpfi it's just to change the manifold dizzy to si and the wiring is for people jumping to si **** I wanna know if I can do mpfi with y8 manifold and dizzy
Are you answering your own questions?
If you want to run 92-00 civic injectors you need to delete the resistor box. You can run an adapter like pictured below.
http://www.ebay.com/itm/Civic-CRX-Integra-Fuel-Injector-Resistor-Box-Delete-Plug-OBD0-OBD1-JDM-Vtec-ZC-/201554995432?vxp=mtr&hash=item2eed9d28e8
Civic CRX Integra Fuel Injector Resistor Box Delete Plug OBD0 OBD1 JDM vtec ZC | eBay
t-axiom1
Sep 18, 2005 08:35 PM
