D17A2 OBD1 INDIVIDUAL COIL PACK
Old Apr 4, 2016 | 11:03 AM
amadeuscr's Avatar
Default D17A2 OBD1 INDIVIDUAL COIL PACK
We've been working on a EM2 to try to make it OBD1 and keep the coils functioning ... here it is the write up , this could be interesting for some
TrojanTuning.com ? Ver Tema - D17A2 OBD1 INDIVIDUAL COIL PACK
Old Apr 4, 2016 | 12:18 PM
m_shake's Avatar
Default Re: D17A2 OBD1 INDIVIDUAL COIL PACK
While this is very cool, https://www.hondata.com/kpro-d17 this just seems so much easier.
Old Apr 4, 2016 | 01:47 PM
amadeuscr's Avatar
Yes it is , but a lot more expensive , plus remember that a coil on plug was developed by us in the middle of the project that will be useful for all OBD1 scope.
Old Apr 4, 2016 | 09:52 PM
toyomatt84's Avatar
Sanji
Backdating to OBD 1 seems a bit odd, since K-Pro is readily available for the D17.
Old Apr 6, 2016 | 04:20 PM
spAdam's Avatar
Loved
Community Favorite
Interested to see the coil on plug implementation to the distributor, otherwise seems like a ton of work to make a dinosaur ecu work on a more modern car.
Old Apr 7, 2016 | 01:19 PM
amadeuscr's Avatar
I would not include the word dinosaur having in mind that the majority of people here has cars from 88 to 00 and a lot of people still use OBD1 and 2002 car is not that modern :D ... don't get me wrong , I thought the same thing but is not a lot of work . plus ... the technology is no that different , pretty much all sensors are the same excluding IACV ... so the technology on the side of the ECU is not that advanced either . the only new thing is multiplexing which is not a big of deal. and as you said ... the whole story was based on making a Coil Controller for OBD1 ... Im attaching a picture of the updates of the coil controller.
Old Apr 7, 2016 | 01:23 PM
amadeuscr's Avatar
The controller is based on Arduino Board and uses 8 wires
1 - RED - 12V
2 - BLACK - GROUND
3 - ORANGE - IGN COIL 1
4 - BLUE - IGN COIL 2
5 - PURPLE - IGN COIL 3
6 - GREEN - IGN COIL 4
7 - WHITE - SYNC (INJ1)
8 - YELLOW - ICM SIGNAL
Old Apr 7, 2016 | 01:27 PM
amadeuscr's Avatar
There was some improvement after tuned on dyno but I believe my engine is not in great shape its all stock and with stock exhaust including catalitic converter . My believe is that after an upgrade in exhaust system it will improve a lot more.
**BLUE** GRAPH IS STOCK WITH STOCK ECU
**RED** OBD1 WITH COIL CONTROLLER
Old Apr 25, 2016 | 06:52 PM
halfakneegrow's Avatar
what were you guys using for tuning?
Old Apr 26, 2016 | 09:31 AM
amadeuscr's Avatar
Crome
Old May 25, 2017 | 02:40 PM
ES1_OBD1's Avatar
1 - RED - 12V
2 - BLACK - GROUND
It's hard to tell what wire goes to what number on the board, can you explain better?
I think it's
pin 4 coil 1
pin 5 coil 2
pin 6 coil 3
pin 7 coil 4????
pin 12 inj1
pin 8 ICM signal
viking-101
10
Feb 22, 2012 01:46 PM
bb6_00
Jan 26, 2009 09:45 PM
marc-111
19
Jun 20, 2006 09:40 PM
Ruby Civic
Nov 27, 2004 06:00 PM
