Mini-me swap - d16y7 block + JDM d15b (P08) VTEC head
Old Apr 3, 2016 | 05:27 PM
AcroSilme's Avatar
Default Mini-me swap - d16y7 block + JDM d15b (P08) VTEC head
Okay so I have a d16y7 block with a JDM d15b head currently peiced together and runs but without the proper ECU It has the stock p2e and wiring harness from a 96 dx hatch but I want to complete the swap. What would I need to finish it? Thank you for any help.
Old Apr 4, 2016 | 07:34 AM
Former User's Avatar
Default re: Mini-me swap - d16y7 block + JDM d15b (P08) VTEC head
What specific JDM D15B head? Post the head code.
https://honda-tech.com/honda-civic-d.../#post48684945
https://honda-tech.com/honda-civic-d...-here-3210150/
Old Apr 4, 2016 | 07:36 AM
AcroSilme's Avatar
P08-1 9/3
Old Apr 4, 2016 | 07:43 AM
Would an OBD1 head in an OBD2 car pass emissions in your state/country?
What ECU do you plan to use?
Old Apr 4, 2016 | 07:46 AM
AcroSilme's Avatar
My state doesn't do emissions so I wash going to use a p2e ECU and chip it with a p08-1 chip but I have no idea how to go about completing the swap after that
Old Apr 4, 2016 | 07:55 AM
You can't chip an OBD2 ECU.
Old Apr 4, 2016 | 07:56 AM
AcroSilme's Avatar
P28 is ob1
Old Apr 4, 2016 | 07:57 AM
Originally Posted by AcroSilme
P2e is ob1
Nope
P2E os OBD2, just like your 96 Civic.
Old Apr 4, 2016 | 07:58 AM
AcroSilme's Avatar
I meant p28
Old Apr 4, 2016 | 07:59 AM
I meant p28
Most P28 ECUs are OBD1, but some are OBD2.
But you could chip an OBD1 P28.
Old Apr 4, 2016 | 08:01 AM
AcroSilme's Avatar
So could I run that
Old Apr 4, 2016 | 08:06 AM
Yes.
You need to run VTEC wires to the ECU, and you won't need the CKF sensor. You should be able to use the OBD2 wires for other sensors, but some connectors may need swapping. Does the P08 head come with a distributor and its connectors?
Please check out the FAQs sticky for mini-me swaps.
Old Apr 4, 2016 | 08:41 AM
AcroSilme's Avatar
Yes it does but it is still running on the p2e ECU so Vtec Will not enable
Old Apr 4, 2016 | 08:51 AM
Note that the VTEC wires comment was meant for the set up using the proper ECU, which obviously requires VTEC.
Old Apr 4, 2016 | 08:57 AM
AcroSilme's Avatar
Oh yeah of course
Tim Watford
Mar 22, 2016 06:51 PM
Dawolf
Feb 8, 2016 03:28 PM
CRXREFIC
Nov 21, 2009 11:26 AM
B20inDCinLBC
Apr 8, 2009 02:00 PM
Black-Ty [EG6]
Dec 9, 2007 12:11 PM
