Sulfer smell.....
Old Nov 7, 2002 | 04:22 AM
desync's Avatar
Default Sulfer smell.....
I've been noticing a sulfer smell off and on from the exhuast.... Should I try some higher octance gas, or just go ahead and replace it?
I'd make a test pipe, but until I swap motors I'm stuck with emissions requirements (wich this car passed at the end of august......).
Old Nov 7, 2002 | 05:51 AM
Chiovnidca's Avatar
Default Re: Sulfer smell..... (desync)
I usually recomend trying a different brand of gas. Sometimes they get some that has a higher sulfur content, which causes the stink.
Old Nov 7, 2002 | 06:14 AM
tonyxcom's Avatar
its your cat.
Old Nov 7, 2002 | 06:18 AM
RedHatch's Avatar
Default Re: Sulfer smell..... (tonyxcom)
is it new? because i heard that the exhuasts are protected with a liquid that burns when you drive and it goes away after a week or so...
Old Nov 7, 2002 | 07:34 AM
Kalokohan's Avatar
New User
its your cat.
agreed or it could be a bad o2 sensor. Are you running a testpipe?
Old Nov 7, 2002 | 07:40 AM
Chiovnidca's Avatar
its your cat.
It's not the cat.
Old Nov 7, 2002 | 07:43 AM
tonyxcom's Avatar
Default Re: Sulfer smell..... (Chiovnidca)
its your cat.
It's not the cat.
Well I will share an experience I had. Long time ago my car (G20) had this sulfer smell for about a month. When I would sit and idle it would smell like fart everywhere. This was over a 1 month period with gas from many different places.
Finally got around to changing the cat, and the smell went away.
Seen a few friends go through the same thing as well.
Old Nov 7, 2002 | 07:52 AM
VTC_CiViC's Avatar
Yea a strong sulfer smell is usually a sign of the cat going bad/clogging up.
Old Nov 7, 2002 | 07:57 AM
Chiovnidca's Avatar
Sometimes it takes a little while to burn all the sulfur out of them. If you replace the cat and get another tank of gas with a high sulfur content you'll be right back where you started. (With a lighter wallet.)
Old Nov 7, 2002 | 08:00 AM
tonyxcom's Avatar
You may have a point there. But after I changed my cat, I didn't have the problem anymore and neither did my friends.
Old Nov 7, 2002 | 08:05 AM
Chiovnidca's Avatar
It doesn't come up that often anymore. Gas nowadays is alot cleaner than it used to be. Still every once in a while they get a bad batch.
Old Nov 7, 2002 | 08:09 AM
tonyxcom's Avatar
Well, next time it happens, I will just sit it out and see if it goes away on its own. But I can remember it getting worse as time went on. And replacing the cat fixed it completely. But I will see what happens next time.
Old Nov 7, 2002 | 08:29 AM
Guam_CiviC619's Avatar
Mexico's gas has a high sulfer content. You may notice that while driving a round down there.
spAdam
10
Aug 29, 2014 03:02 PM
92civicfreak
50
Dec 3, 2007 03:03 PM
ShinotakuX
Nov 5, 2007 01:25 PM
G2DAB18
Jun 13, 2005 10:01 PM
EKcivic1230
Apr 12, 2005 09:07 AM
