Sulfer smell.....
Sulfer smell.....
I've been noticing a sulfer smell off and on from the exhuast.... Should I try some higher octance gas, or just go ahead and replace it?
I'd make a test pipe, but until I swap motors I'm stuck with emissions requirements (wich this car passed at the end of august......).
Re: Sulfer smell..... (desync)
its your cat.
Re: Sulfer smell..... (tonyxcom)
is it new? because i heard that the exhuasts are protected with a liquid that burns when you drive and it goes away after a week or so...
Re: Sulfer smell..... (Chiovnidca)
its your cat.
It's not the cat.
It's not the cat.
Finally got around to changing the cat, and the smell went away.
Seen a few friends go through the same thing as well.
Well I will share an experience I had. Long time ago my car (G20) had this sulfer smell for about a month. When I would sit and idle it would smell like fart everywhere. This was over a 1 month period with gas from many different places.
Sometimes it takes a little while to burn all the sulfur out of them. If you replace the cat and get another tank of gas with a high sulfur content you'll be right back where you started. (With a lighter wallet.)
You may have a point there. But after I changed my cat, I didn't have the problem anymore and neither did my friends.
Well, next time it happens, I will just sit it out and see if it goes away on its own. But I can remember it getting worse as time went on. And replacing the cat fixed it completely. But I will see what happens next time.
92civicfreak
50
12-03-2007 03:03 PM
ShinotakuX
11-05-2007 01:25 PM
