oil light in cluster not working
Old Mar 31, 2016 | 04:27 PM
r_honda's Avatar
Default oil light in cluster not working
ok so i have no oil presuure light in my cluster anymore. at first i thought it was the bulb burned out but i swapped it with my engine light and it works fine. could the sensor itself be faulty? does anyone have a wiring diagram of the oil pressure circuit?
Old Mar 31, 2016 | 05:19 PM
Former User's Avatar
Default Re: oil light in cluster not working
Car information is required for all tech threads. Please read the forum Rules sticky.
Old Mar 31, 2016 | 05:33 PM
r_honda's Avatar
1993 honda del sol d16z6 engine
Old Mar 31, 2016 | 05:34 PM
What troubleshooting have you already done? Does voltage reach the bulb socket?
Old Mar 31, 2016 | 07:10 PM
r_honda's Avatar
i tried swapping the bulb, unplugging the sensor, and i tested for voltage at the wire going into the cluster, i believe the wire is pin A&
Old Mar 31, 2016 | 07:12 PM
What did you find for the Yel wire?
singlecamsaint
Sep 30, 2010 11:27 AM
preludedriva
Nov 30, 2007 11:44 PM
BIGBLOCKEK
Mar 13, 2005 07:21 PM
W.O.P.
Sep 14, 2004 11:38 AM
