95 Civic - d15b swap questions (solved)
Old Mar 31, 2016 | 08:05 AM
tercelrcr's Avatar
Default 95 Civic - d15b swap questions (solved)
Hey ht I do not know if this is the right area for this question or not so here goes. I have a 95 civic email has a d16z6 in it currently. I snapped the crank so need a replacement motor. All I have been able to find in good condition is a jdm d15b vtec. I was wondering is there any weird things or issues I should know about doing this swap? Someone told me I need to change the oil pickup I think it was? Any info is appreciated. Thank you guys
Old Mar 31, 2016 | 08:29 AM
durette121's Avatar
Default re: 95 Civic - d15b swap questions (solved)
it would pretty much be a direct swap, only thing is the d15b you have sourced is it single stage or dual stage vtec?
Old Mar 31, 2016 | 08:40 AM
tercelrcr's Avatar
It's single stage vtec. I didn't feel like messing with dual stage if there was no performance gains from it. Plus my tuning connection hates tuning dual stage.
Old Mar 31, 2016 | 09:30 AM
durette121's Avatar
the dual stage is not to bad i ran one all last summer, difficult to tune as you said. if its the single stage you are swapping it should be easy peasy
Old Mar 31, 2016 | 11:50 AM
tercelrcr's Avatar
OK great I was reading the jdm d15b does not come with a crank sensor I guess. On the obd1 isn't the crank located in the dizzy
Old Mar 31, 2016 | 12:49 PM
durette121's Avatar
you may have to swap the dizzy, are you using the engine harness from the z6? trying to remember if i had to swap mine but it was over a year ago and ive been through 4 swaps since then haha
Old Mar 31, 2016 | 12:55 PM
Former User's Avatar
I'm pretty sure the JDM D15B has a crank sensor (CKP) in the distributor. Maybe the thread you read is referring to the OBD2 CKF sensor (crankshaft fluctuation sensor).
Old Mar 31, 2016 | 02:26 PM
tercelrcr's Avatar
OK I have the dizzy from my z6 if I need it and I believe the guy is using my old harness
Old Mar 31, 2016 | 02:33 PM
durette121's Avatar
you should be fine, whens the swap getting done? throw up some progress pics!
Old Mar 31, 2016 | 04:09 PM
tercelrcr's Avatar
The motor is on its way to the shop in Portland OR from texas. I'm having someone else do it for me because I'm super busy at work this time of year or I would post up progress pics
Old Mar 31, 2016 | 04:12 PM
So the person actually doing the swap doesn't know how to do it?
Old Mar 31, 2016 | 04:26 PM
tercelrcr's Avatar
He knows how to, he runs a Honda only garage in the area. I was asking for my knowledge because the importer of the motor was saying that it did not have a crank sensor on the oil pump and we needed to swap out the oil pump for a usdm one is all
Old Mar 31, 2016 | 05:12 PM
If the mechanic runs a Honda only garage, then he should be able to answer your questions.
People often mix up the CKP and CKF sensors. The CKP is in the distributor of both OBD1 and OBD2 Civics. The CKF is near the crank gear and is typically only present in OBD2 Civics. Therefore, the CKF sensor isn't relevant or needed for your OBD1 swap. However, based on the importer's comment, you possibly purchased an OBD2 JDM D15B. Otherwise, why would he mention it?
Old Apr 12, 2016 | 07:32 PM
tercelrcr's Avatar
Hey, I'm hoping that you may be able to help me out aain. Motor is in and it runs some what. It has erratic idle until it warms up which leads me to believe Iac valve. It has been swapped with the good one from my old motor and same issue. Once warm if you try to drive the car, you can make it abut 100 feet then cel comes in for the iac, and the car starts bucking really bad. Any ideas what else may be causing this. I'm stumped so is the mechanic.
Old Apr 13, 2016 | 10:52 AM
tercelrcr's Avatar
Got it solved sensors plugged in wrong
Old Apr 13, 2016 | 10:58 AM
tony_2018's Avatar
Fish Twig
Certain d15b's do have the crank sensor, you just need to identify if its an obd1 or obd2.
ZenBearClaw
Jun 16, 2006 03:26 PM
JinteDgraM
Mar 20, 2005 09:06 PM
Fab-Works
Mar 30, 2004 10:10 AM
dunkd
Sep 9, 2003 04:23 AM
sportn17
Apr 30, 2002 07:15 AM
