Honda Accord 2001 idle screw 2.3 l LX
Old Mar 28, 2016 | 01:08 PM
Jack jaxz's Avatar
Default Honda Accord 2001 idle screw 2.3 l LX
The idle screw that screws into the throttle body...... Looks like a half moon....... and where the throttle cable meets the wheel connected to the throttle body where the Springs are ..... there's a small nut and bolt idle adjustment... do both idle adjustments do the same thing mechanically..... This would be really helpful thank you....... Do they both open or close the butterfly ..... Or are they two separate settings....... The throttle cable tension is fine.. Just a little Slack thanks again
Old Mar 30, 2016 | 04:15 AM
Turbokraft's Avatar
Default Re: Honda Accord 2001 idle screw 2.3 l LX
Both adjustments should be left as delivered from the factory on a stock car, if you have a low idle clean your throttle valve with carb spray and a tooth brush, avoid spraying the tps area of the throttle shaft. The half moon screw is an air bypass port, the screw w/locknut is throttle angle or minimum airflow adjustment changing this one may set a tps code, air bypass screw no harm done. Clean throttle valve first, adjust air bypass as last resort.
therealmccoy
Jun 8, 2018 09:31 AM
new_climber
Dec 6, 2009 05:44 AM
BallerAccord
Mar 14, 2008 11:29 AM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
hybridEj6
Oct 5, 2006 11:23 AM
