Resetting the check engine light on my '03 CR-V
Old Mar 28, 2016 | 11:45 AM
Blanco'03's Avatar
Default Resetting the check engine light on my '03 CR-V
The car seems to be running great, but the check engine light is on?
How do I find out why?
My 1st thought is to re-set it off & see if it comes back on?
Thanks in advance, I have a 1,500 mile trip coming up & would like to figure this out before hand but only will have maybe one day to deal with it.
Old Mar 28, 2016 | 11:47 AM
Blanco'03's Avatar
Default Re: Resetting the check engine light on my '03 CR-V
What are the typical reasons the light comes on?
Old Mar 30, 2016 | 04:08 AM
Turbokraft's Avatar
Do not attempt to reset the PCM as all diagnostic info will be lost. Most part stores (Autozone, Advance Auto Parts, O'Reilley's etc.) will scan for free. This will get you the dtc and a definition of code set. Common problems are cat efficiency(P0420), and misfires(P0301-P0304) due to improper valve adjustment.
Old Mar 30, 2016 | 04:11 AM
Blanco'03's Avatar
My Mechanic confirmed what I forgot about, It started show the check engine light after my Cat was stolen along with the 2 sensors that are attached.
So he reset it for me. :D
Old Apr 1, 2016 | 08:44 PM
derekbrian's Avatar
It can be due to missing or faulty gas cap that keeps check engine light on. The pressure inside your gas tank is thrown off-kilter when the gas cap is off or not secured properly. To your car's on-board diagnostic system, or OBD system, a change in pressure could indicate a leak in the emissions system, so the light is triggered to alert you to the problem. Replace the missing cap or tighten the existing one to see if the problem goes away. If the problem is not solved you must visit car service center.
Old Apr 1, 2016 | 09:31 PM
Blanco'03's Avatar
Read post number 4.
Corruption
Jun 3, 2006 12:08 PM
97exd16
Apr 10, 2006 08:40 PM
SOLO1racer
Jan 7, 2005 12:49 PM
B18Redline
Apr 7, 2004 08:01 AM
Dan
Nov 19, 2002 10:18 PM
