Dyno sheet for high comp, turbo, vtec killer?
Old Mar 28, 2016 | 07:09 AM
Prokaw875's Avatar
Default Dyno sheet for high comp, turbo, vtec killer?
Hey all. I am trying to do some research for selecting my torque converter on my street/drag S2000 and would like to see some dyno plots of some B/K/F/H for knowledge purposes. My setup is a 11.7:1 F20c, .500" lift OEM VTEC killer cams, on a 68mm Precision. So the closer to that the better... but mainly want to see what torque and powerband looks like if anyone has dyno sheets of high comp 67-72mm cars.
Old Mar 28, 2016 | 08:33 AM
TheShodan's Avatar
Moderator
Default Re: Dyno sheet for high comp, turbo, vtec killer?
You'll find better luck with that situation really in the Drag-Racing section. However, from what I understand, there has not been much feedback lately.
Best of luck.
Old Mar 29, 2016 | 08:17 AM
Prokaw875's Avatar
Best of luck.
Thank you sir
Old Mar 30, 2016 | 03:00 PM
Tony the Tiger's Avatar
I don't have it on my shop computer, but I can post up an F22C, 11.5:1 CR, with the Garrett 67mm GTW3884R on stock cams when I get back home.
However, The VTEC still works and that greatly improves spool. I don't have the files saved, but I remembered on top of my head, that we tried allowing VTEC to engage at 3000RPM and the turbo took another 1000RPM to spool and doesn't even clear 200 WTQ by 5000RPM.
If you plan on running a torque converter, I would probably suggest putting VTEC back in somehow because that would help the converter to flash in much earlier IMO.
TurboEG6262
Mar 8, 2013 12:39 PM
Dunc
Jan 29, 2005 11:18 PM
Vanilla4215
Jul 12, 2002 08:30 AM
int3gra
May 22, 2002 01:40 PM
b19coupe
Apr 13, 2002 01:18 PM
