dash harness issue
Ok guys, so ive been having electrical issues with my teg, my electrical issues started with a mice making a home in my dash and using my dash harness as a chew toy, so my question being i have access to a used harness from a 94 and my car being a 96 does anyone know if they will work? Also not wanting to have an obd2-obd1 conversion harness
I can't remember for sure how the dash harness works plugging into the main harness between obd's.
You'll want to take the dash out doing either harness, but the main harness will be much more work than just the small dash one.
How bad is the harness? is it just behind the cluster area of the harness damaged?
what doesn't work from the damage from the mice?
yes you can use a 96 harness as long as its from the same model just to be safe im not sure if a harness from a GSR or vise versa would be plug and play but just stick with the same model as yours to be safe, 94-99 models are all the same obd2a with the exception of the Vtec models having a vtec dohc engine.
V/\ freestyle
Mar 13, 2011 08:52 PM
crazy_joe
Audio / Security / Video
Oct 24, 2008 08:53 AM
