Interior dash harness help!
Old Jul 28, 2011 | 05:50 PM
shaylude01's Avatar
Default Interior dash harness help!
Alright, ill try to make this short and sweet.
I recently bought a '96 galapagos green DB8 that im planning on getting back together, throwing a motor in, and it will be my slammed/vip/DD. The interior on the car is all tore apart, the Interior dash and all components underneath the dash have been stripped, down to the firewall. The dash harness is gone.
I have a wrecked '96 DC 2 door Integra that i will be using to get the interior back complete on the DB.
My question is this.... The DB Integra has a sunroof. The DC Integra that ill be using the dash harness from DOES NOT. Will the DC dash harness still have the plug on it for an integra with with a sunroof, or am I prettymuch screwed?
Info/Suggestions/Thoughts.... Thanks!
Old Jul 29, 2011 | 02:30 PM
94rs-turbo's Avatar
Default Re: Interior dash harness help!
the dash harness doesn't have that harness, part of the chassis harness
Old Jul 29, 2011 | 07:18 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Use your donnor harness, the sunroof harness plugs into the fuse box. Then you can source the relay harness for your sunroof.
Old Jul 29, 2011 | 08:42 PM
shaylude01's Avatar
Well yeah i kinda knew that but I figured it eventually joined into the dash harness.
Oh? Good to know. Definitly didnt know it plugged into the fuse box. Ill keep that in mind, then i guess all i would have to do is wire the sunroof button on the dash down to the fuse box where the sunroof harness is plugged in. Sort of seems a little easier. Thanks a lot
Old Jul 30, 2011 | 04:31 PM
There is no wiring of the button. The button is on the harness with the relays and it plug into the the rectangle 3 pin port on the fuse block, Ground-12 volts constant-accesorie with key.
Old Jul 30, 2011 | 08:52 PM
shaylude01's Avatar
Even better! I should be in the clear then, I shouldnt have any issues. Thanks a lot man.
Old Jul 30, 2011 | 09:47 PM
Np
D_koschak
Mar 23, 2016 11:14 PM
kasso
Sep 22, 2009 06:13 AM
b.d.racing
Mar 20, 2006 06:17 PM
