96 Civic - Cooling Fans not coming on
Okay so far we have checked:
Cooling fan is good, comes on when jumped to the battery.
Cooling fan ground is good as well, when just jumping positive from battery to positive terminal.
Took out all relays from circuit panel and I heard the magnetic click on all of the relays.
Every single fuse in the car is good and is in tact.
Next i tried unplugging the temp sensor and shorting the pins, and the fans didn't come on.
So what would I do next?
Use the multimeter to test whether the Grn wire in the unplugged ECT switch connector gets battery voltage to body ground and also to the Blk ground wire in the connector.
NAS95
Jan 15, 2018 01:51 AM
