temp runnin high
Old Sep 24, 2005 | 12:39 PM
slowassciv33's Avatar
Default temp runnin high
new to da always had a civic .....my car runs fine but as soon as im stoped for a min or two the car starts to run hott....i neva hear the fan turn on ...could it be a blown fuse? need help asap
Old Sep 24, 2005 | 12:49 PM
Chewie's Avatar
Default Re: temp runnin high (slowassciv33)
thermostat
Old Sep 24, 2005 | 12:53 PM
mlsmith95gsr's Avatar
if the fan isn't turning on, the fuse is a good thing to check as well as make sure all your connections are tight.
Old Sep 24, 2005 | 01:15 PM
DAguyLS's Avatar
I'd say most likely it's your thermostat. It's easy to replace and sounds like it's overdue in your case.
Old Sep 24, 2005 | 02:59 PM
Default Re: (DAguyLS)
the fan is hard wire straight to the battery ...the ground wasnt connected so i conneted it and teh fan went on.......would it turn off by its self if i let it go for a while?
Old Sep 24, 2005 | 07:29 PM
DAguyLS's Avatar
If it doesn't turn off then it's your switch.
Old Sep 24, 2005 | 07:59 PM
hondaxsimike's Avatar
Default Re: (slowassciv33)
if its hardwired straight to the battery then the thermostat would have no control over it therefore it wont turn off on its own
Old Sep 24, 2005 | 09:32 PM
jonnyb123's Avatar
i think its deff a thermostat
Old Sep 24, 2005 | 09:37 PM
Kendall's Avatar
Hell, I usually just hardwire it to a key operated accessory so that it turns on with the car and turns off with the car.
Old Sep 25, 2005 | 06:14 PM
Default Re: (Kendall)
i want to hook it up to a key operated accessory...........where teh best place to run it
NAS95
Jan 15, 2018 01:51 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
lilo_goki
Dec 3, 2007 02:47 PM
s2kkk
Aug 29, 2004 10:35 PM
