swapping ITR master cylinder
Hello, I have a 96 Integra LS, I recently just swapped out my master and booster to a ITR master and booster. I noticed that the hard line adapters don't thread in. The adapter is not the same thickness. What adapter do I need to make the ITR master work in my Integra??.
I believe the earlier ITRs had different size ports on the MC. One port is 10mm and the other is 12mm I think. The later ITRs were the same size on both ports.
I just did this swap on my EK. I bought an MC from an '01 ITR and everything screwed in without an issue.
Only thing I could think of would be the MC and booster not matching up?? Or MAYBE OP is worried about making the brake lines match up perfect. I recall needing to bend the lines a bit to get them to line up with the ITR MC holes.
Have you dealt with the passenger side axle yet? Something like 3 options and it was a pain finding the right one.
SpeedRacerEX-R
Suspension & Brakes
Nov 30, 2015 06:16 PM
Unjockable
Mar 9, 2003 07:46 PM
B18CJDM
Jul 18, 2001 05:15 AM
