HELP I feel like I am screwed!!!
I have a B18C1 and I found out that the person I bought my car from was withholding some info. My fault I should have checked better but here goes. I got the car inspected and while on the lift the mechanic noticed what you will see in the pic. I am leaking oil from there and also the oil pan that isn't installed correctly. I need to know what I am looking at cost wise if the tranny case is cracked or if its not cracked what am i looking at replacing.
At a minimum is needs a new case, possibly a clutch housing as well. Labor for a rebuild and whatever parts are damaged internally. Anywhere from $600-$1,000+ depending on where you have it rebuilt and what needs to be replaced.
