Welding flex pipe
Old Mar 14, 2016 | 06:33 PM
a267mm's Avatar
Default Welding flex pipe
Any tips am having hard time welding these things. Flanges,o2 bungs, joints are fine but flex pipes hard time any tips/advice
Old Mar 15, 2016 | 12:35 AM
kr3w108's Avatar
Default Re: Welding flex pipe
Shouldnt be any different than anything else..... if one piece is thicker than the other. focus on the thicker metal more so then the other.
Old Mar 15, 2016 | 08:26 AM
turbohatch96y7's Avatar
Yeah flex is really easy to weld
Old Mar 16, 2016 | 03:23 PM
a267mm's Avatar
This actually helped out a lot
Thanks
Old Mar 16, 2016 | 03:27 PM
kr3w108's Avatar
Thanks
No problem man.
Old Mar 19, 2016 | 07:25 PM
a267mm's Avatar
No problem man.
Size rod?
Old Mar 19, 2016 | 07:29 PM
aluthman's Avatar
1/16" rod worked well for me.
Old Mar 20, 2016 | 07:15 PM
kr3w108's Avatar
Size rod?
Rule of thumb do not use any filler rod bigger than your base metal. You will put way to much heat into the weld and can easily burn through.
all_motor_mike
Welding / Fabrication
Aug 18, 2010 09:10 PM
gorillam
Mar 2, 2008 03:25 PM
suicide_shift
Nov 5, 2007 11:00 AM
FURACERMAN
Jan 6, 2006 06:32 PM
nickromeo
Dec 30, 2005 01:04 PM
