Loss of power after accelerating
Old Mar 14, 2016 | 05:15 AM
Orie Bethel's Avatar
Default Loss of power after accelerating
When driving everything is fine. If push the pedal down an speed up to about 80mph+ then slow down and go again its like it has no power literally nothing, can barely get out its own way basically haha. If that makes sense
Old Mar 14, 2016 | 05:59 AM
Kickstart1's Avatar
Default Re: Loss of power after accelerating
What year Honda are you driving,and engine/transmission type and miles on it ???.This is info that should be the first thing,as it's like walking in the dark with out a flashlight .What maintenance has been done in the last 5000+ miles if any ???. I would begin with a tune up (plugs/wires/air filter/pcv valve)change the fuel filter too,and go from there .
Old Mar 14, 2016 | 06:07 AM
2001 accord f20b tiptronic has 75000 miles I have just done full service minus wires and fuel filter. Fuel filter in these are attached to the pump itself if I'm correct? Recently bought the car dunno of service history.
Old Mar 15, 2016 | 11:32 AM
Don't know if I explained clear enough. But like I said driving normal everything is fine. Drive it fast either to overtake someone or just go fast. It has no problems but after that when you slow down like to a corner an try to go it doesn't want to go its like its flooded but no gas smell, it does have a little backfire coming from the engine bay though. An after it clears up the car is fine again. I live in the Bahamas so parts I usually have to order myself have no spark plug wires on the island.... any help would be appreciated
Old Mar 15, 2016 | 12:32 PM
holmesnmanny's Avatar
Have you tried pulling codes ? That would be the first place to start. This sounds timing related so it's possible the crank sensor is dirty. Perhaps the spark plugs are bad.
Old Mar 15, 2016 | 12:42 PM
Will check the crank sensor, new plugs are in just no wires. Don't have any engine light but will check for codes
Old Mar 15, 2016 | 12:44 PM
Your car should have coils not wires. The crank sensor is down at the crank. You should clean off the timing pulley as well since the crank sensor reads off of it. Also clean the cyp sensor at the front balance shaft and the pulley.
Old Mar 15, 2016 | 01:25 PM
Car has wires no coils will check everything out though will update. Thanks
Old Mar 15, 2016 | 01:55 PM
TechJohnson's Avatar
Have you tried to clean your IACV? Sticky throttle?
doubleoazn03
12
Sep 5, 2022 09:10 PM
scubacamper
Jan 25, 2013 04:55 AM
cholder919
Aug 28, 2011 01:31 PM
SlowCivic29
30
Mar 7, 2007 10:10 AM
stevescivic
Feb 26, 2006 10:39 PM
