f22b tps issues p12 computer.
Have f22b twin cam non vtec. Working great w old computer. Had to replace w 91comp. Lost tps control. Idle and rev boggy. Only wants to accelerate, negative throttle control.. Do i have to reprogram computer? some people tell me the computer will learn. ? Any advice..
Re: f22b tps issues p12 computer.
The P12 ECU is not programmable.
As far as learning goes, the short term fuel trim, long term fuel trim and ignition are the only things that are learned/changed. That being said, there is a startup procedure for installing a new ECU and setting base idle and ignition.
What year Accord is this setup in?
Is your check engine light on?
If you are saying that you are currently running your car without an upstream O2 sensor, yes that could cause an issue! Really depends on what ECU you are running. In the absence of the upstream O2 the computer would base the fuel and ignition off maps based on TPS and engine RPM.
What computer are you using now, if not a P12?
The old computer (P12) would not learn without an upstream ECU ether. I think you may have been lucky in that the P12 had VE tables for TPS vs RPM that were closer than your new computer.
b18_lover
04-04-2014 10:05 AM
