97 EX F22B1 manual, no clutch pedal!
Hello, I finished my new head install today. Ran great. I drove about 15 miles with a huge grin at well it ran. Then I stopped for dinner, got in, drove about fifty feet and my pedal hits the floor! Towed it home and found I have a leak on what appears to be the seam of the trans below distributor. When I pump the pedal, fluid runs out of that seam. See pic. Car is stuck in neutral and I cannot shift when car is running. When not running I can shift without touching clutch pedal. Any guidance will be appreciated. I might have caused this when I had a jack under oil pan I raised car some more to get access and engine was raised off block snd hung for a couple seconds till I raised block back under pan. ****!!!!
The hydraulic clutch system is a series of lines. A problem with the tranny should have no bearing on the leak. The leak should be able to be fixed.
Also, there is no pic.
phanatic
May 27, 2006 02:03 PM
