97 EX F22B1 manual, no clutch pedal!
Old 03-09-2016, 08:18 PM
jaxflex's Avatar
Default 97 EX F22B1 manual, no clutch pedal!
Hello, I finished my new head install today. Ran great. I drove about 15 miles with a huge grin at well it ran. Then I stopped for dinner, got in, drove about fifty feet and my pedal hits the floor! Towed it home and found I have a leak on what appears to be the seam of the trans below distributor. When I pump the pedal, fluid runs out of that seam. See pic. Car is stuck in neutral and I cannot shift when car is running. When not running I can shift without touching clutch pedal. Any guidance will be appreciated. I might have caused this when I had a jack under oil pan I raised car some more to get access and engine was raised off block snd hung for a couple seconds till I raised block back under pan. ****!!!!
Old 03-12-2016, 12:47 PM
holmesnmanny's Avatar
Default Re: 97 EX F22B1 manual, no clutch pedal!
The hydraulic clutch system is a series of lines. A problem with the tranny should have no bearing on the leak. The leak should be able to be fixed.
Also, there is no pic.
c_era
05-31-2012 07:30 PM
erockharder
02-09-2011 01:15 PM
97whitex
06-26-2007 04:37 AM
carracr625
08-06-2006 06:05 PM
phanatic
05-27-2006 02:03 PM
Quick Reply: 97 EX F22B1 manual, no clutch pedal!
