99 Si windows keep jumping off track
Old Mar 9, 2016 | 05:37 AM
Another_Si_Guy's Avatar
Default 99 Si windows keep jumping off track
I'm prepping car for sale, and I've had a problem where the windows jump off the track ever since I bought it. Its gotten to the point where I just carry a 10mm ratchet and Phillips head screwdriver to fix it every time it happens. Anyone have any idea how to fix the problem? I don't think it's the regulator because apparently plenty of people have tried replacing that to no avail. I also read that cleaning and bending the channel back into place could potentially fix it, or spraying with silicone grease. If anyone has had any luck fixing the problem, please let me know. Any input is appreciated.
Old Mar 9, 2016 | 05:56 AM
Former User's Avatar
Default Re: 99 Si windows keep jumping off track
The problem you describe is generally a bad window regulator caused by a loose central rivet.
Old Mar 9, 2016 | 06:29 AM
Eh2Guanaco's Avatar
Yea the window regulator...would be my bet...what he said^^^^^^
Old Mar 9, 2016 | 09:34 AM
Alright thanks for the response. I'm going to see if i can fix it myself before throwing money at it. I'll get back as soon as I have it all done, and get back to you and let you know whether it works.
Old Mar 9, 2016 | 09:48 AM
Don't guess. Check for a loose rivet joint.
Old Mar 10, 2016 | 05:38 AM
I'll be taking it apart once it stops raining outside. Will be back with updates.
Old Mar 10, 2016 | 12:48 PM
RageKage's Avatar
either of the guide tracks could be loose inside the door. I've had that problem in the past.
Old Apr 3, 2016 | 01:53 PM
Toxin715's Avatar
happened to my window, everything was fine. All it needed was some lubricate on the track and it runs perfect now.
Old Apr 3, 2016 | 02:50 PM
I lubricated with silicon spray and it works a lot better, but I think the rubber track is screwed up. It was all folded inside the metal rail and doesn't want to retain its original shape. I had to superglue some parts of it.
Old Apr 4, 2016 | 02:23 PM
Toxin715's Avatar
out a heat gun to the rubber and keep the window down so it goes back to form
dragonkx
15
Apr 22, 2010 11:59 AM
inthad
Jun 8, 2008 07:18 PM
98DC2teg
10
May 13, 2005 01:56 PM
Irishweird00
Mar 8, 2004 03:56 PM
kilab16a
Oct 2, 2002 08:42 AM
