B1801 my new build motor. BTW can anyone tell me how to remove this damn gear
Old Mar 8, 2016 | 09:28 AM
Stopsign32v's Avatar
Loved
Default B1801 my new build motor. BTW can anyone tell me how to remove this damn gear
Here's the motor I will be building with a Silver Surfer turbo from STC
I'm stumped as to how to remove this gear so I can take off the oil pump and in turn take the crank out.
I feel like this is the key to removing it, but I don't know how.
Old Mar 8, 2016 | 09:50 AM
turbohatch96y7's Avatar
It slides right off
Might be seized.
Ive never dealt with a seized one
Try soaking it in wd40
Or a little heat on the gear
Tap it with a hammer to knock it loose
Old Mar 8, 2016 | 09:52 AM
Loved
Default Re: B1801 my new build motor. BTW can anyone tell me how to remove this damn gear
Do you pry between the oil pump and large gear?
Old Mar 8, 2016 | 10:00 AM
Loved
Just put a huge screw driver behind the large wheel and hit it with a rubber mallet. Damn thing isn't moving a budge. I also sprayed some liquid wrench behind it. I feel I'm doing something wrong here...
Old Mar 8, 2016 | 10:09 AM
You arent thats gear should slide on and off the crankshaft
The crank pulley keeps it in place
Add some heat to it
Old Mar 8, 2016 | 10:41 AM
Loved
Tried again, it isn't moving.
BTW what the hell is a B1801
Old Mar 8, 2016 | 10:42 AM
Did you add heat?
Old Mar 8, 2016 | 10:51 AM
Loved
Yep
Old Mar 8, 2016 | 11:08 AM
Loved
**** I can't even get the damn crank pulley bolt off! ****
This bolt does follow the traditional left loosey rule, right????
84Riceeater's Avatar
Yup, It should just slide off. i would soak it in some Pb blaster.
Old Mar 8, 2016 | 11:12 AM
Loved
I'm using liquid wrench
Old Mar 8, 2016 | 11:15 AM
Loved
Update: Just broke a gear off the larger gear you see on the back.
Slide right off... my luck
ETA is it's still not budged past that one part that went flying across the garage.
Old Mar 8, 2016 | 11:20 AM
What are you using exactly to heat up the gear?
I have like 10 of those gears i can send you
Old Mar 8, 2016 | 11:22 AM
Loved
A torch
At this point I'd like to use some plastic explosive
Old Mar 8, 2016 | 12:23 PM
LightningTeg's Avatar
Community Builder
lolol. Damn that sucks man Never had that problem. Just avoid marring that crank snout
Old Mar 8, 2016 | 01:13 PM
Loved
I think you guys are ******* with me because I'm new to Hondas lol. I have to be doing something wrong.
Old Mar 8, 2016 | 01:18 PM
cruizinmax's Avatar
True story. The gear should come off just like the harmonic balancer.
Old Mar 8, 2016 | 01:23 PM
Loved
So you place a large screw driver between the large gear and oil pump and just like that it comes off? Yea...no
Old Mar 8, 2016 | 02:03 PM
People get banned for trolling tech forums these days
Tread carefully
Old Mar 8, 2016 | 04:09 PM
bergercurtis's Avatar
Put a light tap on the woodruff key with a punch. Maybe that's wedging it in place like a keystone in a bridge.
Old Mar 8, 2016 | 04:45 PM
motoxxxman's Avatar
yes. actually, they're supposed to just slide off by hand, shouldnt even need to use a prybar or screwdriver. things rust though, and they stick sometimes. just keep soaking it in penetrating oil
good idea^.
and because the gear is already broken now, I'd suggest taking a metal hammer and tapping the gear all over the place too to break up the rust. it should slide off eventually. then grab another gear from the guy above
Old Mar 8, 2016 | 05:41 PM
Also.. B1801? Did someone punch the C closed to an O, or what is this engine?
Old Mar 8, 2016 | 11:39 PM
TravisBiggie's Avatar
x2 on this. gear should slide off. I have had issues installing/removing one, and the woodruff key was to blame.
Old Mar 8, 2016 | 11:41 PM
I bet thats a b18c1 block. have you torn this motor apart before? not difficult at all to make it a 0
Sam1am26
Dec 30, 2019 09:50 AM
mouab18c1
Jun 14, 2013 02:11 AM
q16racer
17
Oct 31, 2010 03:09 PM
See Are X
Feb 11, 2005 09:13 AM
See Are X
Nov 12, 2003 04:14 AM
