B1801 my new build motor. BTW can anyone tell me how to remove this damn gear
Re: B1801 my new build motor. BTW can anyone tell me how to remove this damn gear
Just put a huge screw driver behind the large wheel and hit it with a rubber mallet. Damn thing isn't moving a budge. I also sprayed some liquid wrench behind it. I feel I'm doing something wrong here...
Update: Just broke a gear off the larger gear you see on the back.
Slide right off... my luck
ETA is it's still not budged past that one part that went flying across the garage.
lolol. Damn that sucks man Never had that problem. Just avoid marring that crank snout
Put a light tap on the woodruff key with a punch. Maybe that's wedging it in place like a keystone in a bridge.
and because the gear is already broken now, I'd suggest taking a metal hammer and tapping the gear all over the place too to break up the rust. it should slide off eventually. then grab another gear from the guy above
Also.. B1801? Did someone punch the C closed to an O, or what is this engine?
I bet thats a b18c1 block. have you torn this motor apart before? not difficult at all to make it a 0
q16racer
17
10-31-2010 03:09 PM
See Are X
02-11-2005 09:13 AM
