5 CEL codes after engine swap
Hi everyone... It's a 1996 Honda civic So I swap a 96 none VTEC engine for a 98 VTEC sohc wiring harness and computer. Now...I'm getting five codes 1 air control sensor, 2 idle control sensor, 3 MAP sensor, 4 fan temperature sensor ,5 ignition cap. Beside the VTEC is leaking oil from the top I change the gasket for a new one and still leaking ugh. Don't know what to do...
There is no "ignition cap" code. Post the ACTUAL codes. The other four, you either didn't plug in, or didn't plug in correctly. Tell us the wires colors going to each of those sensors.
its not about being a dick to the new guy, its about a total lack of effort in a post asking for free help. how much is an hour of diagnostics at your local shop? if you have your hand out, you can at LEAST try.
This are the codes
P1362
P0113
P1108
P1508
P1259
I took the car to a shop they don't want to spend the time to figure it out plus the cost. I'm putting this car together for my son lol any help will be very appreciated. I will post some pics
P1362
P0113
P1108
P1508
P1259
Reset the ECU to see if all codes return.
https://honda-tech.com/honda-civic-d...lists-1901557/
Auto or manual transmission? What 96 Civic trim (CX, DX, HX, EX)? The IACV previously had 3 wires. Does it now have 2 wires?
P1362 - TDC
P0113 - IAT
P1108 - Baro (bad ECU)
P1508 - IACV
P1259 - VTEC
P1362 - TDC
P0113 - IAT
P1508 - IACV
P1259 - VTEC
OP
lot of mixed items in play
1 what was the original engine?
2 why did you switch to vtec harness?
3 what engine presently in the car ?
a DX 1997 5 speed could have any engine does not help much
Meyerwi
Dec 3, 2013 07:39 PM
skinney6
51
Sep 1, 2012 10:30 AM
zx2gotboost
Apr 22, 2011 01:42 PM
