Ecu help
It is a b20b out of 99 crv, I put the stock b18b cams in it and we put the crank sensor and oil pump to convert it to obd2. It also has the b18 intake and a 65mm throttle body.
99 is obd2a for both the integra and the crv.
using the stock crv ecu may or may not work all that well because you changed the cams and intake manifold, and using a much larger TB. your best bet would actually to convert to obd1 and have it tuned.
allmotorCRX.
13
Jun 12, 2011 06:46 PM
