Oil everywhere, how to clean?
Old Feb 28, 2016 | 09:47 PM
daboy155's Avatar
Default Oil everywhere, how to clean?
So i found out i had a giant hole in my turbo's return line where it was contacting the downpipe(the steel ziptie i used to hold it away came off somehow) even though the downpipe was wrapped. I replaced my oil return line and everything runs great. The problem now is when the car gets up to temp smoke is everywhere from the oil burning off. It's all over the downpipe wrap, oil pan, the entire underside of the car basically. I was thinking of just going crazy with the engine degreaser and brake cleaner and coating everything and powerwashing it over and over. Will this damage anything? Can i spray that stuff on my header wrap(which is on the turbo hotside and downpipe). Any ideas, it's a big mess.
Thanks!
Old Feb 28, 2016 | 10:02 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: Oil everywhere, how to clean?
Just use some degeaser and wipe it all away, use lots of paper towels.
For the wrap, might be worth replacing the wrap.
And do not pressure wash anything with the engine hot.
I would remove the old weap, wipe off as much oil as possible, drive the car a day or 2 so any residue left behind is burned off then wrap some new wrap around it.
Old Feb 29, 2016 | 12:48 AM
hondur's Avatar
Dur Da Dur
5 Year Member
Wash it with the soap gun at a car wash, oil is bad for earth and you shouldn't just wash it into a storm drain or yard. Try to avoid plastic, rubber, and electrical stuff like the alternator especially the alternator. Maybe put a bag over the alternator.
If the power washer has enough pressure to cut you, keep it a safe distance away from the bay so you don't break anything.
Old Feb 29, 2016 | 06:08 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Carwash drains lead to the earth also.
Don't use brake cleaner to clean engines externally, OP. For so many millions of reasons.
Old Feb 29, 2016 | 08:20 AM
MotorMouth93's Avatar
10 Year Member
Put down some sheet plastic to make sure nothing gets on the ground, then some flattened cardboard boxes over that to absorb most of the oil, then go to town with engine degreaser and rags/paper towels.
Old Feb 29, 2016 | 08:54 AM
TheShodan's Avatar
Moderator
Thanks!
While you were replaceing the hose, did you by chance use some thermal sleeving to make sure it wouldn't happen again? It was just a thought to avoid additional issues later one you've cleaned up.
Old Mar 3, 2016 | 11:56 AM
TOO MUCH TORQUE's Avatar
i like to wash engines in this way:
1) Use a cloth to wipe off oil as best as you can (degreaser cannot penetrate thick layers of oil very well)
2) use a degreaser and then use a brush of some sort to agitate the very thin layer of oil(remember, you wiped most of it off in step 1)
3) use a hose and gently spray it off
Old Mar 3, 2016 | 04:28 PM
oldschoolmaster's Avatar
When Did the world go so green
You must be from cali
Old Mar 3, 2016 | 05:24 PM
daboy155's Avatar
Thanks all, got it done without any issues (besides the neighbor telling me he was gonna call the EPA). It runs great now, no more smoke. I did put some extra heat wrap in between the line just in case it comes loose again, so i shouldn't have that happen again
Old Mar 3, 2016 | 07:07 PM
hondur's Avatar
Dur Da Dur
5 Year Member
They should actually have a filtration system...
Old Mar 5, 2016 | 01:33 AM
wunfstgsr's Avatar
Loved
Community Favorite
For future reference look into dry ice blasting! leaves the metal on the head or block, trans looking fresh and clean and wont damage any electrical parts and does a great job of cleaning the engine and anything else really! had a company in Clairemont, CA blast a dirty block and trans and it looked brand new like it was hot tanked and fresh from the machine shop.
Andrew 825SM
Feb 14, 2010 06:05 PM
accord_raffi
Jan 27, 2009 07:29 PM
serious
Mar 23, 2004 10:03 AM
E Swift
Nov 2, 2002 09:17 AM
DC2R714
Jul 19, 2002 05:25 AM
