Brakes grinding weird.
Old Feb 27, 2016 | 08:03 PM
chris d's Avatar
Icon4 Brakes grinding weird.
Hey H-T! Today I noticed my brake pedal felt squishy & I noticed when turning fully left I hear a grinding noise from my passenger front wheel & I saw that the brake rotor was being eaten up on the outside edge... What could cause this? I've searched & all people said was heat shield but it's not lol & it's not a cv axle cause it's a grinding not a clicking noise... It's now just randomly doing it, I did hear a odd sound when I was braking hard yesterday, must have something to do with it. & it's a 1997 civic EX
Old Feb 28, 2016 | 05:28 AM
Former User's Avatar
Default Re: Brakes grinding weird.
Post pictures of the rotor, caliper, and brake pads.
Old Feb 28, 2016 | 11:04 AM
chris d's Avatar
Well I'm at work right now so I was only able to get a pic of the rotor. Any speculations? 😔
Old Feb 28, 2016 | 11:05 AM
chris d's Avatar
I can only hear the noise when turning ��
Old Feb 28, 2016 | 11:35 AM
NotARaCist's Avatar
I never narc'd on nobody!
That looks like something is or was caught under your pad. Pull your pads and inspect them.
Old Feb 28, 2016 | 01:48 PM
chris d's Avatar
okay! I'll update the thread when I do!
Old Feb 29, 2016 | 09:38 AM
OxDseries's Avatar
I had kinda the same issue on my 95 Del sol, the reason why that happened was because the bolt for the axle was loose and as soon as it was returning to tighten, noise stops, but the damage on the Rotor was there already.... take a look on it that may be the reason....
Old Feb 29, 2016 | 09:44 AM
mk378's Avatar
While you have the caliper off, check for any looseness in the wheel bearing. If the wheel wobbles the bearing is bad.
@OxD, driving with the axle nut loose is probably going to ruin the bearing.
Old Feb 29, 2016 | 09:53 AM
OxDseries's Avatar
Indeed... recently starts to make that annoying noise of the bearing going bad... so... but still the issue with my breaks had a similar symptoms and the mark on the rotor on the same area...
White_EG1
Suspension & Brakes
15
Oct 29, 2016 08:41 AM
nonohood69
Jun 12, 2013 07:09 AM
cb450scmatt
May 5, 2008 02:18 PM
msinsky14
May 24, 2007 06:00 PM
Prelussion
Oct 27, 2001 11:09 AM
