Lights and everything work but car won't start.
Old Feb 27, 2016 | 03:22 PM
Brandon808's Avatar
Default Lights and everything work but car won't start.
I have a 2002 Acura rsx type-s. The other day my car just wouldn't start. Has been working fine since I bought it. The lights and everything work. But when I turn the key nothing happens. It doesn't make a sound or anything. Tried to jumpstart thinking it might be the battery at first. But nothing happened.
Old Feb 28, 2016 | 07:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Lights and everything work but car won't start.
Can you push/roll start it ??? If so, check the floorboard to see if there are broken parts of the clutch switch pad there. The parts usually found are shaped like a small round disc (or part of one like pie slices) or a cone shape... and they are usually dark blue or white in color.
The test would be to MAKE SURE the car is in neutral and the e-brake is firmly engaged, reach up to the top of the clutch pedal box and depress the clutch switch and hold it in... and turn the key to start the car. If you cannot reach it yourself from the floor, get someone to help you. If the car starts, then the pad inserted into the clutch pedal arm is missing and thus, not depressing the clutch safety switch/starter relay circuit... meaning the car won't start and no sound is heard.
Old Mar 2, 2016 | 07:37 PM
Brandon808's Avatar
Thanks. That was the problem
moparguy
Sep 22, 2015 03:33 PM
miguey310
Jan 30, 2014 11:24 AM
gustafse
Nov 27, 2011 04:55 PM
Ecskater1313
13
Oct 27, 2008 08:00 PM
trianglegreg
Dec 13, 2005 05:53 AM
