1997 civic b16a starting and running issue
Old Feb 26, 2016 | 10:11 AM
jcartercressa's Avatar
Default 1997 civic b16a starting and running issue
i currrently own a 97 civic with a b16a obd1. i dont drive it everyday so it sits sometimes , anyway it has a running issue. it will run fantastic when the vehicle sits in cold weather for a long time but as soon as u start driving it for a good 2 miles it slowly starts loosing power , and then eventually it just dies and will not start at all . i have noticed tho that the colder it is outside the better it runs untill it warms up. i have replaced the jumper harness at the ecu that adapts the obd1 to obd2 ,because the pins were coming out of the connector. thought that would fix it , but did not. i also replaced the distributor because the winding and secondary resistance on the coil was a little high. i suspect the ecu is faulty but i havent really confirmed it 100% if anyone has any guidance on this issue or has had or seen this problem before fill free to sent a comment or pm me . thanks
Old Feb 26, 2016 | 11:50 AM
oldschoolmaster's Avatar
Default Re: 1997 civic b16a starting and running issue
Your ecu codes and fuel pressure readings would help in diagnosis
Old Feb 26, 2016 | 03:21 PM
I forgot to menton that no codes at all and fuel is at t he correct psi level
Old Feb 26, 2016 | 03:22 PM
I also have preformed a cat pressure test and it came back ok 02 sensor is fine too
Old Feb 26, 2016 | 08:12 PM
White_EG1's Avatar
Have you verified that you're getting good spark and fuel?
When's the last time it had a full tune up?
90da integra
May 20, 2014 02:18 AM
blackEKcoupe
May 22, 2007 02:26 AM
.ShawnD.
17
Jul 2, 2002 06:57 PM
