problem starting 99 civic cupe with b16a swap (HELP ASAP)
i swaped a obd1 jdm b16a in my 99 civic coupe and my civic is obd2 and i put a obd2 distributor harness and ecu and injectors in my car. i got it to run but it wasnt running to full power tues night and yesterday (weds) the car started and was ideling right above 0 just barley running.... so i went down the street and i put it in nutral and the car just died.... so the only way i could drive it was if i steped on the gas right when i started it.... so i drive it to my friends and he got it to idel at 1 then we drove it around the block and pulled in his driveway... then when i went to leave it wont start. it wants to turnover but i cant get it to spark what do you think is causing this problem? distributor is brand new.
thanks kyle
thanks kyle
Re: problem starting 99 civic cupe with b16a swap (blackEKcoupe)
if its not sparking you might check your coil but they get a little pricey you might have a defective cap or rotor so check those too but it could also be just a fuse so it wouldnt be a bad idea to start playing with that power tester
bought a rotor button and still didnt work
so i sent my distributor back and having them send me a brand new one
anyone know anythign else i could check?
Re: (blackEKcoupe)
did you check all of your fuses and run your way down through the sparking system piece by piece with a multimeter to make sure it all has adequate voltage? thats easier than just buying parts to throw at it.
jcartercressa
02-26-2016 08:12 PM
matrinox104
24
05-07-2015 02:40 PM
EK FLY
02-13-2007 07:59 PM
redm3turbo
07-05-2006 12:05 PM
Frcfedintegra
05-24-2003 02:16 PM
