More Radiator Problems :(
Old Nov 6, 2002 | 06:35 PM
kingpen's Avatar
Default More Radiator Problems :(
My radiator is still leaking somehow. Today my car was overheating on the way home from school . I don't know what's wrong with the radiator. It's nearly brand new. Tomorrow I'm going to buy antifreeze and drain it and start all over. Should I buy premixed antifreeze? And what should I do to properly fill my radiator with the fluid. Is there a certain procedure i should follow. If so please inform me. <U>Thanks</U>
Old Nov 6, 2002 | 07:00 PM
viet's Avatar
Default Re: More Radiator Problems :( (kingpen)
if u have a/c..are u runnin your a/c while drivin?..that could also be the problem...i upgraded my radiator to a fluidyne because it always leaked. ...
fluidyne
Old Nov 6, 2002 | 07:57 PM
krazn's Avatar
Default Re: More Radiator Problems :( (viet)
viet..u ony have the prob cause ur a hybrid. king pen... from the looks of it.. you needs a new thermostat. good luck
Old Nov 6, 2002 | 08:01 PM
SpoonFedHatch's Avatar
where is it leaking from??? how much??? i would think that if it's overheating you've got a bad thermostat, but it could also be simply a bad radiator cap or a kinked hose....check the obvious, then if you have no pressure on your uppper hose, it's probably the thermostat
Old Nov 7, 2002 | 03:40 AM
kingpen's Avatar
Default Re: More Radiator Problems :( (SpoonFedHatch)
well when I do catch it leaking its leaking under the a/c. I dont use the a/c right now because Its cold, so i either crack the window or use the heater. Well i think im just going to buy a new cap and check the hoses. But if that fails then maybe a new thermostat. Can i DIY(m) the thermostat or is it too hard? When i refill my radiator with antifreeze what should I do. 50/50% and how do i use "clean water?" No water here is clean except bottled water.
Old Nov 7, 2002 | 03:57 PM
kingpen's Avatar
Just got 50/50% antifreeze pre-mixed. Any suggestions in draining and putting in the new?
vxtirent08
Mar 20, 2008 10:36 AM
tommyt761
Oct 12, 2006 01:00 PM
eastsideATX
Jul 6, 2005 02:56 PM
kingpen
Oct 31, 2002 12:19 PM
EGh22aEG
Jan 9, 2002 06:37 PM
