Need Check Engine Help ASAP
Old Feb 20, 2016 | 01:25 PM
Garry Kuehner's Avatar
Default Need Check Engine Help ASAP
Ok, so I know its been gone over time and time again, but I'm at a stand still.
First things first, I have a 1998 Civic Hatch DX, original motor, blah blah blah
My car is throwing a P0141 code
I needed a new cat so i threw a new cat in the car, I still had the code, so i replaced the secondary o2 sensor, still code immediately
So I did some research, and my 15 fuse is good, so i went and tested the voltage in my black and yellow wire, .7 volts.
So obviously I have a short and its probably the intake bracket. The thing is I have no other codes, no light pulsation, and my car is super low and i have nowhere to work on it at my house. so any solutions before i line up a location to work on my car? I live in NY so I need no CEL in order to pass inspection and my inspection is a few weeks over, so help asap would be ideal.
Thank you
Old Feb 20, 2016 | 02:31 PM
tony_2018's Avatar
Fish Twig
Default Re: Need Check Engine Help ASAP
reset ecu and go for a drive to see if the code comes back. I hope you replaced with "new" parts, and not "new to me" parts.
ezejdm
Sep 27, 2013 06:36 AM
DB1_559
Mar 27, 2008 08:57 PM
civic efb16
Oct 16, 2005 11:57 PM
Sleepin Crx
Feb 5, 2004 01:37 AM
420aNT
Jun 6, 2003 07:05 AM
