99 Civic coupe SFWD Canadian
Old Feb 14, 2016 | 05:09 PM
Th.tune's Avatar
Default 99 Civic coupe SFWD Canadian
I start honda drag racing in 2008 with d series motor ran 11.78@121 mph on pump gas d16a6 and since 2012 i work back on this car and switch it to a b series platform
the goal for now its a high 9 sec car with 700whp
Engine
B18C1 82 mm css block
CP Piston 10:1 compression hd pin
Crower H beam connecting rod
Stock GSR crankshaft
ATI Engine damper
Stock Port GSR cylinder head 3 angle valve job with bronze guide iconel valve
Vtec deleted pin kit Speed factory
Custom Camshaft my own spec
Edelbrock Victor X intake manifold with ford mustang 75mm TB
Moroso 5.5 liter oil pan
4 port custom catch can
Transmission
Oem mixup gear set
CC twin disk clutch
Turbo setup
Borgwarner Airwreck S362 .91 a/r T4
Full race Twin scrool top mount manifold
60 mm tial wastegate
Charged pipe 2.5 hot side 3.0 cold side
Tial type Q blowoff valve
Ecu
Hondata s300 with traction control setup
Boost by gear mac solenoide
Custom buid harness
Blaster ss coil stock distributor
Fuel setup
RCI 5 gallon sump fuel cell
T1 Dual 044 pump setup
Weldon regulator
ID 2000 injectors
Precission 750 hp intercooler core
Chassie
SW race car 12 point roll cage
Kirkey race seat
5 point harness RCI
Quick released Stearing Willwood hub
Blox drag coil over suspension
Weld Wheel 24.5 Slick
Old Feb 14, 2016 | 05:34 PM
Th.tune's Avatar
Default Re: 99 Civic coupe SFWD Canadian
CSS Block 82mm
supertech valve train
I just have to finish fuel setup and wirring is 90% done first start up in two week maby
Old Feb 14, 2016 | 08:15 PM
kr3w108's Avatar
Nice man, looks good.
One thing i noticed is your cage, the dash bars are so far away from the pillar of the car wouldnt it get in the way of vision?
Old Feb 14, 2016 | 11:09 PM
Th.tune's Avatar
thanks buddy
the vision is good
the cage pre fab by sw race car give me no choice to have that distance
Old Feb 17, 2016 | 03:20 PM
rudebwoy's Avatar
Originally Posted by Th.tune
thanks buddy
the vision is good
I have the same cage and spent double the price for shipping to me because they refused to ship APO, I was so disappointed when I saw that roof halo being so narrow they usually go wide as possible on front and bend the ends to bring them back to the main hoop, but I guess they have a new operator on the fabrication, this is my 3rd S&W cage and the one for the EM1 coupe is the worse one. broke my spirit really. I may have to just run it 8 point.
Old Feb 17, 2016 | 04:41 PM
Th.tune's Avatar
Originally Posted by rudebwoy
I have the same cage and spent double the price for shipping to me because they refused to ship APO, I was so disappointed when I saw that roof halo being so narrow they usually go wide as possible on front and bend the ends to bring them back to the main hoop, but I guess they have a new operator on the fabrication, this is my 3rd S&W cage and the one for the EM1 couple is the worse one. broke my spirit really. I may have to just run it 8 point.
you right its not the perfect fit i did the best i can and i have all the good clearence from the nhra rule book when im sit in the car
Old Feb 18, 2016 | 07:26 PM
kr3w108's Avatar
as long as it fits in the rules i guess its ok....
Old Feb 26, 2016 | 07:11 AM
Th.tune's Avatar
Pro series carbone sycro
1 gear gsr (3.230) 2 gear gsr (1.900) 3 gear SI (1.458) 4 gear SI (1.107) Final drive ls (4.266)
Old Feb 26, 2016 | 09:39 AM
Th.tune's Avatar
the 1.107 4e gear with ls 4.266 final drive look for me the best 153/155 mph ratio for a motor rev 9500 9800 on a 24.5 slick
Old Feb 26, 2016 | 09:41 AM
AllShowNoGo727's Avatar
Love the project, the car is looking great. Keep up the great work
Old Feb 28, 2016 | 06:21 AM
Th.tune's Avatar
Thanks buddy!
Old Feb 28, 2016 | 11:53 AM
sr20paisa's Avatar
is this the same coupe on youtube that ran an 11sec with a turbo d16a6?
Old Feb 28, 2016 | 12:40 PM
Th.tune's Avatar
Yes back in 2012 on pump gas 91 oct fuel
https://honda-tech.com/forced-induct...0trim-3067695/
Old Feb 28, 2016 | 02:33 PM
sr20paisa's Avatar
sick! i saw the body then i remembered the video of it idling or dynotesting not sure, really cool to see you in the forum man
Old Mar 1, 2016 | 05:11 PM
Jeebus's Avatar
Are you aloud to have cage past the fire wall in SFWD? I didn't think you were.... or maybe that's just True Street.
Old Mar 1, 2016 | 07:13 PM
Th.tune's Avatar
Yes you can SFWD and True street can have a cage pass the fire wall if the suspension mounting stay in stock location you ok.
Old Mar 2, 2016 | 02:36 PM
Jeebus's Avatar
Sorry, I guess I misunderstood. I thought the firewall had to be untouched, and you needed to have full aprons. I guess I've been reading into it too much. Nice build BTW.
Old Jun 17, 2016 | 10:12 PM
Th.tune's Avatar
Fire up is close
Old Nov 15, 2016 | 12:50 PM
Th.tune's Avatar
Its time to working back on it !
bauergold
Sep 6, 2017 08:49 AM
thomaskreutzer
Apr 13, 2014 07:31 AM
thomaskreutzer
Apr 13, 2014 07:27 AM
prostreetonline
Sep 8, 2004 05:55 PM
HYBRID_H@TCH
Oct 7, 2003 05:01 PM
