Yes... Another start problem
Old Feb 8, 2016 | 02:40 PM
someguyw/acivic's Avatar
Default Yes... Another start problem
95 civic. Would start then immediately shut down. Didn't hear pump priming up when I turned key and I replaced the main relay less than a year ago.
I put a new fuel pump and filter still same problem.
I randomly have power to pump. I jumped the 1-7 I think, in the relay and pump turns on. Then I jump the other two(I forgot which ones) and nothing happened. Both fuses are good. Sometimes the pump primes up no problem and starts fine but it's random.
Old Feb 8, 2016 | 04:16 PM
Former User's Avatar
Default Re: Yes... Another start problem
Did you jump pin 5 to 7?
Old Feb 9, 2016 | 09:52 AM
Originally Posted by slomofo
Jump 1-7
Jump 5-7
Jump around
Jump around
Jump up
Jump up and get down
Never realized until this post that diagnostics keep you physically fit.
Old Feb 11, 2016 | 08:34 PM
Yes I did. 1 to 7 the pump turned on. 5 to 7 nothing. The fuses are good. Today went out to start, started just fine. Like I said its intermittent. Maybe a short somewhere but the wiring under dash is a rats nest from PO
Old Feb 11, 2016 | 08:37 PM
Try installing a new fuse 24.
Old Feb 27, 2016 | 08:55 PM
Old Feb 27, 2016 | 09:02 PM
Tried different fuse. No go.
I'm really at a lose with this thing. I got power at the pump when I turn the key to start. Should I have power when key is in the 2 position?
The ground at the pump is good to.
Old Feb 28, 2016 | 05:27 AM
Test the ignition switch.
Old Feb 28, 2016 | 06:30 AM
bdj1973's Avatar
SolBlu's Helpful Del Sol Site
There is a diagnostic to check for that and just about everything here.
https://honda-tech.com/tech-misc-15/...mp%5D-2961164/
It actually links back to here.
Old Feb 28, 2016 | 06:45 AM
Where? Link to the specific section that you think is relevant.
Also, a diagram for testing the ignition switch can be found in the FAQs sticky.
wwolf771177
Mar 25, 2013 02:54 PM
Hazeburner
Aug 31, 2010 09:41 AM
zennx2k3
Nov 12, 2008 04:03 AM
FrOsTwHiTeDC4
Jul 7, 2007 06:28 PM
gloryhog
Jul 30, 2004 06:14 PM
