BRMS ac/ps compatible D-series ramhorn
Old Feb 8, 2016 | 07:51 AM
NWDyno's Avatar
Default BRMS ac/ps compatible D-series ramhorn
Anyone have any pictures of this manifold installed? I know they went out of business. Just wanted to get some ideas of how folks ran their oil return, downpipe, and ic tube. Thank you
Old Feb 8, 2016 | 05:27 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: BRMS ac/ps compatible D-series ramhorn
I'm going to point you in the direction of this post, which, had you searched, you would have found pretty easily.
Originally Posted by TheShodan
2 particular reasons.
1) Their "A/C compatible" kooks manifolds don't allow for any clearance for water lines, whether you're using a GT Ball-bearing or journal bearing turbocharger.
2) It also puts the compressor cover unreasonably close to the webbing to where you're really limited to only T04E compressor covers, even if there is room below the runners themselves for a T04S. The others listed allow for a T04S.
Here's an example of Revillusion's BRMS manifold. This fits Way too close to the block itself, being a T04E cover.
Although they say A/C Compatible, it makes me think that it was designed only for 5 bolt Ford-SVO style housings. There has to be some adjustment for the T31 4 bolts housings.
No provisions for a good block adapter water fitting kit
BRMS has much better business practices than SLS, (which I used to try to work with for a LONG time), but it reminds me of rushing to making a Kooks manifold, "just so that they can make one too." No disrespect for them, as from seeing them personally the build quality is solid, just no regard for other extras that a turbo user may need. If one wants to label this as a "gripe", this is the only one.
Old Feb 8, 2016 | 05:30 PM
whitesihatch's Avatar
They are no loner around, however Mike Drum their old fab guy still makes quality manifolds.
Old Feb 8, 2016 | 09:36 PM
underrated's Avatar
The desires manifold fits nothing the the pic posted.
OP you will need a smaller sized waste gate, a tial with block the lines for the compressor.
Old Feb 9, 2016 | 07:38 AM
NWDyno's Avatar
Thank you, I did search for about an hour sunday morning with no luck other than the B-series like you have posted.
Yeah I heard they have been out of business for a while. This is on a customers car...he bought the manifold with intentions of keeping ac and ps, but ended up just keeping ps.
Yeah I agree, i dont see how you can fit ac with this..which is not a problem for me anyways beings the customer ended up getting rid of his ac.
Old Feb 10, 2016 | 01:10 PM
underrated's Avatar
good deals
Old Feb 10, 2016 | 10:59 PM
Kevinio's Avatar
Sorry for the offtopic, but where can I get these coolant drain plugs:
Old Feb 10, 2016 | 11:26 PM
underrated's Avatar
Have you tried b&r fittings?
Old Feb 11, 2016 | 02:05 PM
NWDyno's Avatar
Front Block Port Adapter
Old Feb 11, 2016 | 09:25 PM
Kevinio's Avatar
Thanks guys!
Skip01
Jul 26, 2011 11:28 AM
JKov240
Apr 12, 2011 08:23 PM
smaggs
May 7, 2010 02:28 PM
b18sihatch
Oct 1, 2006 06:14 PM
