Sway bar end link options (Stock LCAs)...already searched
Old Feb 6, 2016 | 11:26 AM
ONe21's Avatar
Default Sway bar end link options (Stock LCAs)...already searched
Alright, alright. I searched to no avail so here we go.
What I have:
-1998 civic dx sedan
-Type R rear sway bar
-Lowered approximately 1.8-2.0"
-Stock LCAs
-Worn out spherical sway bar end links (unknown brand installed by previous owner)
So what are my options? All of the adjustable ones seem to require aftermarket LCAs, except for BLOX (which doesn't have the best reputation). I don't want to install fixed end links and have jacked up geometry that will wear them out quickly. I want something that will last for more than a few years (I'm only occasionally a "spirited" driver).
Old Feb 6, 2016 | 12:58 PM
ONe21's Avatar
Default Re: Sway bar end link options (Stock LCAs)...already searched
Since I know everyone loves pictures, here are a couple of pictures of my current setup.
Old Feb 7, 2016 | 08:33 PM
98civdx's Avatar
Master Detailer
You can use OEM style 99-00 SI endlinks on the car.
With spherical (heim joints) they dont have the best streetablitily, and wear out pretty quick, Especially the cheap ones. I had blox endlinks that lasted about 6 months .
Old Feb 8, 2016 | 07:42 AM
tony_2018's Avatar
Fish Twig
I don't see anything wrong with em1 si endlinks, not sure how your search results didn't bring that up.
Old Feb 8, 2016 | 10:36 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
He's looking for adjustable end links. Rules out stock.
eH.
Old Feb 8, 2016 | 10:42 AM
tony_2018's Avatar
Fish Twig
I can't think of anything else that is adjustable, just gonna have to sand off that rust, by another cheap set and make sure it doesn't rust.
Old Feb 9, 2016 | 04:46 AM
ONe21's Avatar
Thanks for the replies. It looks like my original post required a little comprehensive reading, so I'll clear things up a bit.
I am not set on getting adjustable links. The impression I got during my search is that, on a lowered vehicle, the OEM end links would have less than optimal geometry and it would accelerate failure. If that isn't the case, then I'll use OEM.
Can anyone verify this?
Old Feb 9, 2016 | 12:08 PM
tony_2018's Avatar
Fish Twig
Depends on how low you're going. I can see why they made adjustable ones. I just didn't realize they DID.
Old Feb 9, 2016 | 05:45 PM
98civdx's Avatar
Master Detailer
I'm running OEM style endlinks F/R on my civic, and it's pretty low.
Adjustable endlinks are pricey for quality units, and even then they might not even last that long on a street car.
Unless you can find endlinks that offer adjustablity and use ball joint style ends.
Old Feb 12, 2016 | 05:08 AM
ONe21's Avatar
98civdx, that's the information I was looking for. Thanks to everyone for your help.
Old Mar 1, 2016 | 04:05 PM
ONe21's Avatar
I ended up ordering a pair of 99-00 Si end links (not OEM) and discovered that the threaded rod doesn't extend far enough through the anti-sway bar to attach a nut
Is this because they are not OEM or is something else wrong here?
Old Mar 1, 2016 | 07:33 PM
98civdx's Avatar
Master Detailer
it's those spacer looking things you are using.
Old Mar 2, 2016 | 05:09 AM
tony_2018's Avatar
Fish Twig
what the hell is that spacer doing there? I don't even see that on the parts diagram
Old Mar 2, 2016 | 03:43 PM
98civdx's Avatar
Master Detailer
EG/DC sway bars can't be used with a 99-00 style endlink without spacers.
The proper way to do it for the spacers to be inside the sway bar... that's the ghetto rigged BS way.
Old Mar 2, 2016 | 04:11 PM
ONe21's Avatar
EDIT: After research I found this adapter . Is this what you are referring to? This is a fairly common modification, is ASR the only ones with a solution?
Old Mar 2, 2016 | 07:37 PM
98civdx's Avatar
Master Detailer
Yep. those are what were talking about.
Not the only, but those are the cheapest i've seen them.
Old Mar 3, 2016 | 02:45 AM
tony_2018's Avatar
Fish Twig
Funny....cuz my hardrace endlinks fit fine w/o spacer. dc2 rear swaybar.
Old Mar 3, 2016 | 03:55 PM
98civdx's Avatar
Master Detailer
Are you sure it's a Dc bar?
the hole on the eg/dc is larger and the endlinks will flop around. sure it they will fit, but it's not correct.
Custard
Jul 17, 2017 05:14 AM
Verkmiester
Mar 24, 2016 03:23 PM
Ritchie
Suspension & Brakes
26
Oct 16, 2010 09:29 PM
Mikes2000civicsi
Mar 28, 2008 09:41 AM
ef9itb
Jan 25, 2008 09:05 PM
