Need advice 00 Civic EX engine issues
Old Feb 5, 2016 | 06:36 PM
SalsaGuy's Avatar
Default Need advice 00 Civic EX engine issues
My son's 00 Civic EX D16Y8 170K miles has oil leaking into the coolant it also has over heated. It still runs and gets good MPG. I've read how the block is porous or head gasket maybe bad for the oil to get into the coolant.
I'm torn between trying to replace the head gasket?
Replace the engine (rebuilt)?
Run it until it dies or has more serious issues?
The body is OK and has some hail damage. Basically for a 16y/o car it isn't bad.
Any thoughts or suggestions?
Old Feb 5, 2016 | 06:52 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Need advice 00 Civic EX engine issues
As much as I hate to say it, you need to read the rules. This is an entirely opinion-based question, and you need to make that decision.
Old Feb 6, 2016 | 01:04 AM
hondur's Avatar
Dur Da Dur
5 Year Member
head gasket ~350
engine ~2,000
hmm
Old Feb 6, 2016 | 05:51 AM
Former User's Avatar
If the engine has been severely overheated, then replace it.
Otherwise, compression test the cylinders and do a leak down test on cylinders with low compression.
DasShuk
Honda Civic (2001 - 2005)
May 23, 2019 09:14 AM
Telecatster
Dec 9, 2012 02:24 PM
Metal Typhoon
10
Jul 26, 2006 05:05 PM
sporkcrx
Apr 30, 2004 12:30 AM
ionic_slim
Jun 3, 2002 05:14 AM
