Full race set-ups
Old Feb 5, 2016 | 03:57 PM
rossyrossb18a's Avatar
Default Full race set-ups
What is everyone's thoughts on full race turbo set-ups....? Not quite sure what I want to run yet and honestly don't know where to start with picking the correct setup. Been looking and reading at a lot of different threads on here.
Plans:
B18c block
Bored/sleeved 84-85mm
Gsr head pnp and 5 angle valve job
Skunk 2 ultra manifold
Not sure about cams... Leaning towards skunk2 pro 2 or 3
Skunk2 lma assemblies
Not sure about rail and injectors yet
Hondata s300
As far as HP/tq numbers.... Pretty much the most I can make.
Just looking for opinions and suggestions. Not looking for someone to tell me exactly what to buy or build. I'm very mechanical inclined but this will be my first turbo build. Had a built ls in this eg before I decided to yank it cuz I wanted more.
Old Feb 5, 2016 | 04:17 PM
DC4KiD's Avatar
Default Re: Full race set-ups
Kind of hard to say what is better for your needs with no info of what injectors and type of fuel you're going to use.
Old Feb 5, 2016 | 04:23 PM
NotARaCist's Avatar
I never narc'd on nobody!
Full Race makes good kits, if you want to go with an inclusive kit. You could save money by piecing together your own setup, but then you have to make sure you have everything you need, which can be intimidating for a first timer. If you want to go that route, though, check out the FAQ sticky - it will tell you what you need.
Junk2 No. Bad. Stop. They are a bad company, and there are other companies who make equal or better hardware that are more worthy of your money. You don't strictly need an aftermarket fuel rail until you're pushing four digits of power - until then, it's just bling factor. RC's website has a great injector calculator, found here, that you can use to figure out what size you need.
Old Feb 5, 2016 | 04:28 PM
I did play around with the rc injector thingie today. Lol and I think I need 1000's.... Not sure.... I have also been reading the FAQ sticky too. Fuel is gonna be 93 **** water.
Old Feb 5, 2016 | 04:36 PM
I'm confused by the second part of your response Notaracist... Lol what's Junk2?
I think that is a lot of my problem is I am overwhelmed with all the research that I have been doing. In turn it is intimidating me as far as what to run and what not to run. I like the idea of buying an inclusive kit seems easier. But yes I can see the point of piecing it all together to save some moola..... so cofusing!!!!!
Old Feb 5, 2016 | 04:44 PM
NotARaCist's Avatar
Just google "Junk2" and you'll see exactly what I'm talking about. Skunk2 is a **** company.
Old Feb 5, 2016 | 04:52 PM
ahhhh i see.... hmmmm I haven't had any issues with any of their products. I have found them to be readily available and quite reasonably priced. I would love to find some other products to use if thats the case. Being I have seen the amount of posting you do and your full array of knowledge.
Old Feb 5, 2016 | 05:21 PM
NotARaCist's Avatar
It's not necessarily their products. Their hardware isn't bad, per se. It's the people running the company. It's the way they run their company. There are other companies out there that are more worthy of your money.
Old Feb 5, 2016 | 05:35 PM
Totally understandable. I've dealt with many a companies that are like that being I've been in the auto game for QUITE a few years now. So I Guess the true reason for this post is I'm having trouble in trying to figure out what trim and a/r i would need to run. More or less how to figure that out..... I've seen a lot of posts about the gt35r. I obviously want to run a turbo that is reputable.... Not an ebay special. No offense intended.
Old Feb 5, 2016 | 05:39 PM
Not gonna lie... First time I saw one of your posts and your quote in your sig.... I was kinda offended.... I'm like do I know this guy? Lmao
Old Feb 5, 2016 | 05:45 PM
NotARaCist's Avatar
For proper turbo selection, you need to decide on a power goal. Different power goals will require different turbos, as well as different supporting mods. Stock B series, you're limited to 300, maybe 350 WHP. Forged internals will bring you up to around 400. Beyond that, you'll need more supporting mods. In short, the more power you want, the more expensive it'll get.
Pick a power goal, or at least a budget, and work from there.
And yeah, the sig is a whole other thing about a guy who made some...let's call them uncouth comments about another individual who is better known in the same field of work, and in the process, made a complete *** of himself.
Old Feb 5, 2016 | 06:00 PM
Gotcha. Ok well then I guess I have some more thinking to do. Budget isn't an issue(basically have the ability to get whatever I want). I will be driving this eg more on the street then I will be the track. It will be all forged internals. I know I left a lot off the plans list but I was just trying to get some opinions. I've at least made one decision... I'm going with a equal length ram-horn manifold. Lol
Well I'm glad the quote has nothing to do with me. At least I hope not. Hahaha
Old Feb 5, 2016 | 06:35 PM
Geis's Avatar
Member for nearly 10 years and only 13 posts?
That an accomplishment
Old Feb 5, 2016 | 06:46 PM
Yea tell me about it..... I do ALOT of reading and lurking. LOL
Old Feb 6, 2016 | 04:39 AM
805 Integra's Avatar
Heres a full race ac ram horn very clean welds inside and out, the pictures don't do it justice was its much cleaner than it looks. I can send you more pics later if you send me a pm.
You might want to base your turbo according for what and how you plan on using it. As far as other companies go I know lighting teg just got one from spooling performance, maybe he could share some pics of the inside
Old Feb 6, 2016 | 05:21 AM
Thank you very much. I do like the looks of the ram-horn. I'm thinking thats the way I want to go. I'll figure it all out slowly but surely. I've got plenty of time. Still considering an inclusive kit. I was looking at the go-autoworks site last night too. They have some very nice set-ups also.
Old Feb 6, 2016 | 11:58 AM
VegaS10's Avatar
I've been very happy with my Go-Autoworks kit.
Greg is great people.
Old Feb 6, 2016 | 01:15 PM
2kdrift's Avatar
x2 GO auto FTW
Skunk2 Isnt all that bad really they do make good stuff
Old Feb 6, 2016 | 05:22 PM
ls joker's Avatar
Loved
goautoworks is damn good. greg is the man.
skunk2 is okay. ive never had any problems with their products.
Old Feb 6, 2016 | 05:39 PM
supersilverdc2's Avatar
sheepey makes some good quality stuff too.
check out my setup-to-be
Old Feb 8, 2016 | 04:36 AM
Thank you all very much. I did actually stumble across the sheepy site a few days ago. Im still searching and putting together a plan. All of your help has been greatly apprecated!
Old Feb 8, 2016 | 05:15 AM
LightningTeg's Avatar
Community Builder
Cant really give you advice with "As much power as I can make".
On 93, that is your limited factor and safely 450whp-500whp depending on how efficient everything is.
Old Feb 8, 2016 | 05:52 AM
Over the weekend.. playing in the garage I made that desicion. Im going to be shooting for between 5-600hp. Hopefully I can pull closer to 600.
Old Feb 8, 2016 | 07:06 AM
Community Builder
Going to need Meth , E85, or race gas which will determine what injectors and fuel pump you need
Old Feb 8, 2016 | 05:28 PM
NotARaCist's Avatar
Pump 85, a flex fuel sensor, compatible ECU, and a competent tuner could get you there when the gas is good.
