del sol clunk on warm start.
Old Feb 2, 2016 | 03:34 PM
MattsLegit's Avatar
Default del sol clunk on warm start.
Hello guys I have a 1993 Honda delsol a d16z6 5speed.
I noticed recently that I get a loud clunk coming from the engine. The only time it makes the clunk is after the car has been fully warmed up and restarted.
I had my girlfriend start the car multiple times while I listened to where its coming from. It's definitely not a mount or the starter its coming from the head/block. So i'm wondering whats causing this a backfire maybe? Valves touching the piston?
I replaced my headgasket 6 months ago and got the head milled and block resurfaced. well 2 months ago my water pump started leaking so I threw a timing belt, tensioner and water pump on.
I noticed when making sure everything was in time my cam gear was either 1 tooth to far one way or the other. So I might need an adjustable cam gear.
The clunk didn't start until recently so i'm not sure if that has any significance to my problem.
Here is a link to video of an Acura with the exact same noise. I can get a video of mine instead if needed. anyone have any ideas or thought on my problem. The car runs great besides that.
Old Feb 3, 2016 | 12:01 AM
JarvisW's Avatar
Sol to Sol
Default Re: del sol clunk on warm start.
Starter isn't disengaging.
Old Feb 3, 2016 | 05:59 AM
MattsLegit's Avatar
It doesn't sound like the starter it sounds like its coming from the motor. I forgot to mention that my starter went bad a few months ago aswell and I got a reman. I'll try to make sure the sound isn't coming from the starter and might replace it.
If you think it's the starter why would it do it only on a warm start after being ran for a while.
Old Feb 3, 2016 | 10:00 PM
JarvisW's Avatar
Sol to Sol
All I know is I had a sound exactly like that Acura, and it was the starter.
TeknikDC2
Jan 13, 2010 04:07 PM
blazianasian06
Jun 17, 2009 06:25 AM
honda_90
16
Mar 12, 2009 12:54 PM
orsosolare
Oct 30, 2008 08:24 AM
krca21
Jan 29, 2007 01:54 PM
