97 delsol front/rear sway bar on ek hatch
Old Jan 31, 2016 | 11:47 AM
POE's Avatar
POE
Default 97 delsol front/rear sway bar on ek hatch
I have a 98 cx Hatch and came across a del Sol si front and rear sway bar . I went to install the rear today and it seems like it was a little short and one of the sub frame bolts wouldn't line up with the D bracket. I've read about budget sway bar installs but wasn't able to find anyone who used a del Sol sway on a EK , does anyone have this setup or know anymore about what it takes to get the OEM bars on my car?
I am aware I need the LCA for the front sway, but haven't worked on that yet, just the rear. Thanks
Old Jan 31, 2016 | 12:03 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: 97 delsol front/rear sway bar on ek hatch
I believe you'll need the 99-00 Si brackets and end links.
eH.
Old Jan 31, 2016 | 01:25 PM
98civdx's Avatar
Master Detailer
there's a bracket that the D bracket bolts to. Sounds like your missing that.
12/13 on this diagram.
https://www.google.com/search?q=Hond...sHxjCtISAnw%3D
Old Jan 31, 2016 | 03:13 PM
POE's Avatar
POE
eH.
I thought from my research the Integra bars are the ones that need the end links and brackets...
Old Jan 31, 2016 | 03:58 PM
98civdx's Avatar
Master Detailer
Not sure where you saw that, but it's 100% incorrect.
Old Jan 31, 2016 | 04:03 PM
POE's Avatar
POE
I have that bracket 12 13 and that side bolts up, the other side does not have that bracket . and that's the side that doesn't bolt up. But it is not meant to be on the other one just the smaller D bracket..
Old Jan 31, 2016 | 04:12 PM
POE's Avatar
POE
10-4, do you have the del Sol say bars or familiar with them on an EK, I just want to know if the front will bolt up and what I need for the rear if the bar and brackets work or need fabing .thanks
Old Jan 31, 2016 | 05:14 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Other than diameter, what's the difference between a 92-95 Civic, 94-01 Integra or 94-97 Del Sol anti-sway bar?
eH.
Old Jan 31, 2016 | 07:34 PM
98civdx's Avatar
Master Detailer
The only difference in the sway bars besides the diameter is the EG/DC used a completely different endlink. In that case you'd need a bushing to go inside the hole for the end link to be able to use a 99-00 endlink, or aftermarket.
Can you post pictures? This should be a complete bolt on process.
I currently have a bar for a DC on my civic. (Eibach, but that doesn't really matter)
Old Jan 31, 2016 | 08:05 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
So what you're saying is the the DC/EG end links are what's needed on a 96-00 Civic, not the Si? (Real question, not being facetious.)
eH.
Old Feb 1, 2016 | 08:56 AM
POE's Avatar
POE
I can get some pictures next weekend .
Thanks for the help
Old Feb 1, 2016 | 05:08 PM
98civdx's Avatar
Master Detailer
eH.
No, the EG/DC enlinks will NOT work on a 96-00, they are a totally different design. However you need "spacers" that allow you to use the 99-00 OEM SI endlink, or aftermarket if you choose to do so.
These are what's needed to put the EG/DC sway bar in a 96-00 civic.
https://www.jhpusa.com/store/pc/view...idcategory=640
I really lost on the issue here. Short of something being damaged, there is no reason why this shouldn't work. It's a bolt on process.
Old Feb 16, 2016 | 09:01 PM
POE's Avatar
POE
Thanks guys, so Just a recap the 99-00 si end links I need or the after market from jhpusa will both work?
Sorry I haven't posted a picture of the d bracket issue I'm having on the right side I haven't had a chance to get back under the car, I will follow up when I get out there. It just seems like the holes don't line up with the bracket one does but the bottom is to close .
Old Feb 22, 2016 | 01:46 PM
POE's Avatar
POE
This is a picture of the brackets not fitting the bottom hole on the subframe. The driver side fits (the bigger bracket ) and also the stock end links. That I'm not sure will work or not .
Old Feb 22, 2016 | 01:56 PM
tony_2018's Avatar
Fish Twig
You need the em1 D brackets, bushings and endlinks in order to fit that onto a 96-00 civic.
Old Feb 22, 2016 | 05:20 PM
POE's Avatar
POE
Do I need these spacers from jhpusa.com In addition to the d bracket and end links from 99-00 si ??
Old Feb 22, 2016 | 05:32 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Yes. Post #12.
eH.
Old Feb 22, 2016 | 06:06 PM
98civdx's Avatar
Master Detailer
Ahh. I see now.
ok, so the D bracket doesn't bolt onto the subframe. it bolts onto the bracket that is on the sway bar now. (left side)
Next, those endlinks will not work. You need 99-00 SI "style" endlinks. OEM or aftermarket, doesn't matter.
You WILL need the sway bar spacers also.
Old Feb 22, 2016 | 06:20 PM
POE's Avatar
POE
Ahh. I see now.
Awesome thanks man , I think with all these additional pieces I may just buy an aftermarket sway bar and call it a day, lots of money for only a 13mm rear sway.
Old Feb 22, 2016 | 06:25 PM
tony_2018's Avatar
Fish Twig
I bought everything for an EM1, thats all I'm going to say.
used an integra LS rear sway bar, em1 brackets and endlinks. no spacers.
Old Feb 23, 2016 | 05:37 PM
98civdx's Avatar
Master Detailer
as mentioned in our message, it's still going to require all the same things to use a sway bar on this car. aside from the ~$30-40 the spacers.
also, you will to get some different bolts to actually secure the brackets to the subframe. Factory 99-00 si bolts will not work.
Old Feb 24, 2016 | 11:15 AM
OxDseries's Avatar
Post some pics after doing the job for visual info for future reference..... Thanks
JiNxXx0013
Suspension & Brakes
Sep 16, 2017 07:26 PM
Diamond Co
Suspension & Brakes
12
Dec 3, 2012 08:39 AM
DC2#309
Apr 5, 2005 07:54 PM
wdskuk
Sep 29, 2003 06:54 AM
bearboy80
Apr 29, 2003 03:48 PM
