Obd2 LS in ef
Old Jan 30, 2016 | 12:13 PM
91sihatchback's Avatar
Default Obd2 LS in ef
What do i need to convert from obd 0 to obd 1.
Old Jan 30, 2016 | 01:05 PM
oldschoolmaster's Avatar
Default Re: Obd2 LS in ef
Ask siri
Old Jan 30, 2016 | 01:54 PM
v4lu3s's Avatar
RTFM
the ability to click on the FAQ !
Old Jan 30, 2016 | 10:35 PM
tim_adams85's Avatar
This.
Old Feb 5, 2016 | 12:53 AM
Need more info
Old Feb 5, 2016 | 04:17 AM
v4lu3s's Avatar
RTFM
I can't type any slower. click on the faq, then scroll down to OBD0-to-OBD1 conversion
if that is not enough i recommend hiring someone to do the work.
Old Feb 5, 2016 | 07:07 AM
acmoc's Avatar
They just passed new smog laws in California where 99 and newer cars simply must pass an ecu scan that finds no cels.
This would make passing emmissions with my 91 OBD0 crx way easier.
If I convert to OBD1. Could I do this?
Or do I have to be OBD2?
Old Feb 5, 2016 | 07:55 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
If you converted your LS engine to 99 specs, maybe, you would get away with this.
Old Feb 5, 2016 | 08:22 AM
4drEF's Avatar
Keyboard Humorist
1996 (95~1/2) is when OBD2 hit the market.
I believe any OBD2 vehicle qualifies for the ECU smog test.
If you do an engine swap, then you would need the full OBD2 system.
The hard part to this conversion to your car is the pressure sensor in the fuel tank. There just isn't anyplace to put it.
If you have a CEL code, then you fail.
(search for MIL in this PDF)
https://www.bar.ca.gov/pdf/Smog_Chec...ence_Guide.pdf
This does not GUARANTEE that you will simply get an ECU check.
I talked with my smog guy and he said the foundation for the ECU check is now in place, but it's going to grow over the years.
There is supposed to be a trigger added to the system that randomly selects cars to run on the dyno even if they are OBD2.
As far as I understand, if the engine was offered in several years where it was equipped with OBD1 as well as OBD2, then you can change out all the OBD relevant electronics and hardware to change to the desired OBD.
Old Feb 7, 2016 | 02:14 PM
Just wanna know what parts do i need
Old Feb 7, 2016 | 06:30 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
If you read through the FAQ, there are write-ups telling you everything you need to know on how to convert.
Old Mar 27, 2018 | 01:00 PM
Takumi Kurosawa's Avatar
Ai need some help can any one help me please ay have an honda civic coupe 1.6 vtec 1999 ai change de original block d16 y8 with an d16 y3 because de original blows up sow ai realize that the d16 y3 is an non vtec it dosen't have the knock sensor what should ai do to reconect this sensor because ai don"t have now place to put on this block 😔
amish_assassin88
Jul 19, 2009 01:53 PM
amish_assassin88
Jul 19, 2009 01:52 PM
technine
Engine Management and Tuning
Apr 30, 2009 07:12 PM
dubster99
Feb 28, 2005 02:22 PM
SpoolinEK9
Nov 7, 2004 01:02 PM
