b16 valve clearances
Old Jan 29, 2016 | 05:18 AM
CRXVTECKE's Avatar
Default b16 valve clearances
hello, what are the best adjustments of valves for b series?
Old Jan 29, 2016 | 05:48 AM
v4lu3s's Avatar
RTFM
Default Re: b16 valve clearances
The ones in the service manual work really well.
Old Jan 29, 2016 | 06:44 AM
93egSLEEPER's Avatar
They can be found in the SEARCH button too
Old Jan 29, 2016 | 10:04 AM
CRXVTECKE's Avatar
I know the honda oem ...my question is if there is any better
Old Jan 30, 2016 | 06:39 AM
K20.ek's Avatar
.006-.007in on intake and .007-.008 on exhaust
Old Jan 31, 2016 | 10:01 AM
CRXVTECKE's Avatar
iam from portugal... 19 intake and 21 exhaust in auto data...
Old Jan 31, 2016 | 10:24 AM
K20.ek's Avatar
Yes that's what we use here in u.s
The tighter u can get within those specs I heard is little better performance. That's what manual book calls for anyways.
Old Jan 31, 2016 | 01:20 PM
CRXVTECKE's Avatar
15 / 20 is nice? because the tool as 15 and 20 not 19 and 21 -.-
Old Jan 31, 2016 | 10:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The confusion within the numbers given here by many different posters is that the references are given in two different systems... SAE and Metric.
The SAE (English Standard) reference of .006" Intake/.007" Exhaust is measured in thousandths of an inch. The factory Honda service manual expresses a range of adjustment given in SAE as .005"-.007" Intake and .006"-.008" Exhaust.
The Metric equivalent would be .196mm-.276mm Intake and .236mm-.315mm Exhaust.
The theory of tightening valve lash/clearance to increase performance is scientifically accurate, however, the amount of increased lift will be nominal, at the expense of decreased oil film between the rocker arm and camshaft lobe... increasing the potential risk of camshaft lobe wear. Also remember that as the engine warms up, heat expands metals and those clearances shrink from the preset values. More aggressive camshafts tend to require a little more oil film to survive, requiring an extra thousandth or two to minimize lobe wear.
I suggest you follow the manufactures guidelines as well as those suggested by any aftermarket cams that you use.
Old Feb 1, 2016 | 02:40 AM
CRXVTECKE's Avatar
ok thanks
civtic
Feb 23, 2008 09:19 AM
nexgen91
May 3, 2007 11:15 AM
bigdaddyradde
May 13, 2006 12:05 PM
LsVtecTeg95
Dec 1, 2004 08:55 PM
slow hatch
Mar 5, 2003 04:58 PM
