Toyo proxes TS-1 how do these tires handle ?
Old Nov 6, 2002 | 02:51 PM
DC2 12's Avatar
Default Toyo proxes TS-1 how do these tires handle ?
hey does anyyyone have these Toyo's. And if u do can you tell me how they perform. Cause im thinkin of gettin a set.
Old Nov 6, 2002 | 03:05 PM
yoshi234's Avatar
I shoot brides
Default Re: Toyo proxes TS-1 how do these tires handle ? (hoacun)
they're great for street, but for track....
yshi - who blames it on the tyres but it's most likely the driver
Old Nov 6, 2002 | 03:11 PM
ZygSpeed's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (yoshi234)
Yoshi -- just the rear Mugen Bar?
Don't feel bad, I spun (only once) on like lap 3 of the first expo at BW!
2000 Integra R #760's Avatar
yea street they are good but i dont think they will hold up for track usevery well....they are kinda sloppy
Old Nov 6, 2002 | 03:18 PM
jetydosa's Avatar
25 Year Member
Default Re: Toyo proxes TS-1 how do these tires handle ? (2000 Integra R #760)
Ah, ya know...Im just not that impressed with mine handling wise. They do not have the gokart type response the RE010s did. I keep the pressure 37-38ish usually or they are just too sloppy and really get on my nerves. I will say they are kickass in rain though, are quiet, and ride smoothly. Also, I have about 10k in them and they still look good for at least another 10-15k. I hope they dont last that long though
[Modified by Jetydosa, 7:19 PM 11/6/2002]
Old Nov 6, 2002 | 03:24 PM
gandhisan's Avatar
In the picture that goes before that one it looked like your tire hit dirt, at that point it doesnt matter, any performance summer tire would have done the same thing, snap oversteer. You need rally spec tires to fix that T1-S is good for touge, and im sure its good for track
Old Nov 6, 2002 | 03:29 PM
tonyxcom's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (gandhisan)
Everyone I have talked to says the T1-S are a good daily driver tire, but suck for just about anything else. The only people I have heard say good things about them are people that are toyo dealers.
And I am sure someone is going to say that is what they use for the Speed Touring Car Championship....but it doesn't matter. Those tires are shaved, which makes them a little better, and mainly becuase they are a series sponsor and nobody can run anything else but that tire. I also heard that the compound was somewhat different (can take more heat) then what you can by on the street but I have yet to confirm that. But that was from someone who did a few races in the series last year and has a couple of sets.
Old Nov 6, 2002 | 03:38 PM
00MRSi's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (tonyxcom)
Damn, Yoshi any damage on 234?
Old Nov 6, 2002 | 03:51 PM
sil's Avatar
sil
plus their entire suspension is tuned around these tires, which I doubt anybody on the street can say they do.. regardless these are great street tires.. needs some stiffer sidewalls but great in the rain..but my next tire will most likely be the stickier and cheaper azenis..
Old Nov 6, 2002 | 05:10 PM
whiteGSR's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (sil)
has anyone both the t1-s and the s-o3s?
if so, how does the 2 compare?
Old Nov 6, 2002 | 05:15 PM
bhcvc's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (whiteGSR)
how about t1-s vs. re730 vs. kuhmo mx? how do these compare?
Old Nov 6, 2002 | 05:25 PM
J_Edwards's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (bhcvc)
All I know is that I went from Azenis to the T1-S . The Toyo's are decent...nothing in comparison to the Azenis though....but I got them for wet weather performance where the Toyo is and the Azenis are .
Old Nov 6, 2002 | 06:06 PM
rodimus's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (mr. clockwork)
toyo doesn't have much of a sidewall.
i assume that since the 205/50/15 size is like 5lbs lighter than the azenis
in the same size.
Old Nov 6, 2002 | 06:10 PM
yoshi234's Avatar
I shoot brides
Default Re: Toyo proxes TS-1 how do these tires handle ? (EVOL)
the yokohama a520 have ALOT stiffer sidewall. I filled the a520 to 32psi and it rides pretty firm on the street. The same 32psi on the toyo's made the car fill underinflated, but it sure was more cushy w/ my firm sus
yshi -who'd like to try some Kumho MX
Old Nov 6, 2002 | 06:11 PM
DOHC_VTEC786's Avatar
New User
In the rain Toyo T1S are great
I cannot say anything about them for dry weather
Old Nov 6, 2002 | 06:48 PM
tonyxcom's Avatar
in the same size.
I bet dubs are lighter then Azenis.
Old Nov 6, 2002 | 06:54 PM
01CWITR's Avatar
i have a set of T1S they don't have sidewall so i don't really like this tires..
if i ever get another chance to replace tires i will go for Azenis !!
Old Nov 6, 2002 | 07:17 PM
sil's Avatar
sil
these things only come in 17-20"?!?! (from tirerack) Anybody else carry this tire.. if not maybe the yok es100==good?!?!
Old Nov 6, 2002 | 07:28 PM
SurferX's Avatar
How's the A520 and T1-S compare? Those seem to be the only two decent tires in 195/55-15 besides the insanely priced RE010 which I miss dearly.
Old Nov 6, 2002 | 07:30 PM
vtec.dc2's Avatar
had these on stock 15x6 wheels, 195-55-15... worst tire ever... very soft sidewalls..
Old Nov 6, 2002 | 07:33 PM
J_Edwards's Avatar
Default Re: Toyo proxes TS-1 how do these tires handle ? (vtec.dc2)
I have to say that the RE010 is the only tire that I have had which is comparable to the Azenis...and they were much better in the rain than the Azenis are....too bad they are sooo expensive. $$$$$
JN who can't wait until the summer starts again so I can go back to the Azenis...
Old Nov 6, 2002 | 07:39 PM
Leo's Avatar
Leo
I thought the same thing for the first 1000 miles. Then, they got much better. I usually run them 40F/38R, and that does the trick. I would imagine they would be much better with a shorter sidewall on a larger wheel.
hmongboyLS
Sep 25, 2003 02:07 PM
momo48
Jul 9, 2002 08:29 AM
citanest
17
Nov 27, 2001 07:10 AM
TaboR
Nov 24, 2001 07:17 PM
Type Goch
Jul 10, 2001 09:03 PM
