Tire Issue
Old Jul 9, 2001 | 03:09 PM
Type Goch's Avatar
New User
Default Tire Issue
well, my front tires are starting to bald up. Would you guys recommend switching them with the back or just swap them with new race tires. This is for the expo. Also what do you recommend? Stock size...or 205/ 50/15's?
[Modified by Type Goch, 12:11 AM 7/10/2001]
Old Jul 9, 2001 | 03:18 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire Issue (Type Goch)
You have two different issues: what to do on the street, and what to do on the track. If your fronts still aren't yet down to the wear bars, you can rotate them to the back and put the rear ones (with more tread) on the front, to balance out the wear.
As for the track... If you have a lot of track experience, sure, get an extra set of wheels and some track tires (like A032R in 205/50-15). But if you've never been on the track before, don't bother, since you won't be using the tires or the car to its full potential anyway; you'll be fine with the stock RE010 in 195/55-15.
yoshi234's Avatar
I shoot brides
It's kinda hard to say w/o actually seeing the tires, but just rotate front-to-back for now.
fwiw: Kelly went to buttonwillow last year on what I thought were low tread, but 10K miles later he finally changed them this past weekend.
yoshi - who recommends j00 check out my Azenis I'll be mounting this week
Old Jul 9, 2001 | 07:11 PM
bus stop's Avatar
Default Re: Tire Issue (yoshi234)
Speaking of Falken Azenis......They are great tires, I just got mine last week and I already tried them on the local AutoX over the weekend
These tires are very grip....better than the RE-010 a lot. Almost as good as the Yoko A032R ( IMO )
I will call the Azenis as a street tire with race compound performance in it
Old Jul 9, 2001 | 07:39 PM
R0476's Avatar
And where did you get these tires from?? Thanks.
Old Jul 9, 2001 | 09:20 PM
Pistonhead's Avatar
New User
Rotate them, and have a seperate set of 205/50-15 A032Rs. By mounting even softer, higher performance rubber on the front, and leaving the rear tires RE010s, you will have comparitively less traction in the rear than the front, so I am predicting oversteer. Which can be dangerous. Cars usually do not wreck because of understeer.
Old Jul 10, 2001 | 12:38 AM
Type Goch's Avatar
New User
Default Re: Tire Issue (ITR-01-269)
what if i had the race tires in the back with stock 010's in the front? understeer?
Old Jul 10, 2001 | 07:17 AM
yoshi234's Avatar
I shoot brides
Default Re: Tire Issue (R0476)
I got them from http://www.onlinetires.com
Old Jul 10, 2001 | 09:08 AM
arren123's Avatar
Holy crappers! They actually come in 215/45/16 's?! And they are only $116 each? And they are better than the R010's? !
Need to know a few things on it though.. What's the treadwear on yours? What size are you running? And are they also ok for the street?
I plan to do some autocrossing and mostly highway driving. So I have one last question. Are they safe in the rain?
Old Jul 10, 2001 | 09:24 AM
bus stop's Avatar
Default Re: Tire Issue (arren123)
IMO--they are better than RE-010
I'm using 205/50/15 on my stock rims. The treadwear is 200.....don't let that number fool you, the tires get pretty stick after heat up ( in AutoX ) and even has more grip than RE-010.
And I don't see any problem in rain too
Old Jul 10, 2001 | 09:34 AM
yoshi234's Avatar
I shoot brides
I got 205/50R15 and treadwear is 200.
I look at these tires as the reverse of AO32s...trackable street tires
t00 bad j00 din get them last week when they were $20 cheaper They're still a good deal at the "new" price though.
-y
Old Jul 10, 2001 | 09:50 AM
arren123's Avatar
Great.. I missed the low price..
I'm having a problem wearing down my PZero's though.. I got them in March.. I'll need to drive harder and go to more AutoX's so I can wear them down and get the Falkens
Old Jul 10, 2001 | 09:53 AM
Tarmac's Avatar
Huh? I thought this was the main reason for track disasters. Someone takes a turn to hot, too late to brake, OOPS...
Old Jul 10, 2001 | 11:50 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire Issue (Tarmac)
Big time. Same type tires front and rear are STRONGLY recommended. Don't be foolish...
Not necessarily. Understeer may cause cars to go off under control, but oversteer more often causes cars to spin out of control. Another big cause of accidents is understeer, where the car puts two or four wheels off, then gets turns back towards the track, the tires grip, and you've immediately got severe oversteer, with the car shooting across the track to the opposite side.
Old Jul 10, 2001 | 12:07 PM
Austin's Avatar
Yes, they have them in 215-45/16, i had them installed last Saturday, and I can tell you that they are fairly sticky, I'm loving them so far...but then again I am coming from **** Nitto NT-450's...I'll let everyone know what I think of them after the autocross this Sunday...so far on the mountain twisties that I drive they are stickier than I care to drive.
Austin
Old Jul 10, 2001 | 12:16 PM
yoshi234's Avatar
I shoot brides
Default Re: Tire Issue (00itr0757)
dammit!
i just got a call back from onlinetires...
I ordered 8 of these suckers in 205/50R15, but the Falken warehouse only has 6 and the they don't know how long it will take to get the other 2.
now, should I wait for the other 2 or should I cancel the 4 of them and get them in 215/45R16? hrm/ness
oh jeah, the first 4 tires are going to TypebRo. The other 4 was for me, but now i'm SOL - bah!
what to do, what to do ? ? ?
Old Jul 10, 2001 | 05:49 PM
bus stop's Avatar
yoshi234.......try Sears Autocenter, someone told me Sears is one of the main Falken dealer !!
The Falken Azenis is going to be popular....I just found out Onlinetires up the price from $60 to $80 on 205/50/15 !!
I got mine my Vulcantire....$60 each.....
Old Jul 10, 2001 | 07:46 PM
yoshi234's Avatar
I shoot brides
Default Re: Tire Issue (WhosITR)
well, I ended up going w/ 215/45R16. Bart @ America's Tire Co sold them to me for $93ea. Should be on my car by Fri
Old Jul 10, 2001 | 09:03 PM
Type Goch's Avatar
New User
what to get yosh....stocks?
Soku1kcivic
19
Dec 14, 2008 09:28 PM
Godspeed07
16
Mar 9, 2008 06:57 PM
nsxtasy
19
May 22, 2003 09:14 AM
nsxtcjr
Apr 23, 2002 09:15 AM
TaboR
Nov 24, 2001 07:17 PM
