HELP!! my car won't start!
Old Jan 21, 2016 | 02:58 PM
Edgar Camino's Avatar
Icon4 HELP!! my car won't start!
i drive a 1994 honda eg and my car won't start, it just cranks but thats it. when i turn the key the dash lights don't come out. sometimes my car turns on and i drive it around for a bit and when i park it it won't turn on anymore. i changed the fuel pump, fuel filter and ignition switch, but it still don't turn on. can some one please help me and tell me what the problem could be. thank you.
Old Jan 21, 2016 | 03:28 PM
Former User's Avatar
Default Re: HELP!! my car won't start!
Test the ignition switch.
Old Jan 21, 2016 | 06:57 PM
NotARaCist's Avatar
I never narc'd on nobody!
When the car won't start, check your spark - what color is it? When the car won't start, does the CEL come on for ~2 seconds then turn back off when you turn the key to ON(II)?
Old Jan 21, 2016 | 07:04 PM
my sparks are good, when i turn the key none of the daslights turn on, the dash lights turn on only when i try to turn on the car, but it only cranks.
i just changed the ignition switch, idk if that could be the problem or some wires that could be burn
Old Jan 21, 2016 | 07:22 PM
NotARaCist's Avatar
Check and clean your thermostat ground.
Old Jan 21, 2016 | 11:27 PM
Pat337's Avatar
I drive a 95 'sol VTech. I had a similar sounding problem this past summer. I had to replace my distributor assembly as there was a faulty sensor that couldn't be replaced. It cost much more than just replacing a cap and rotor.
Old Jan 22, 2016 | 12:41 PM
eh2_Trav's Avatar
So just to clarify, the dash lights only come on when youre trying to crank the car over?
albert7
29
Feb 7, 2017 03:12 PM
jdmmilf88
Jul 15, 2012 12:15 PM
Draiga1988
Dec 22, 2011 07:24 AM
slowcrxsib16
Jul 31, 2006 07:00 PM
nezr
Jan 18, 2005 01:01 AM
