B16a2 swap into Del Sol
Old Jan 21, 2016 | 02:29 PM
TeamRED_07's Avatar
Default B16a2 swap into Del Sol
I'm planning to get a Honda Del Sol and swap a B16a2 engine and transmission into it. I know it will fit because Del Sol also came with b16a3. Del Sol are OBD1 and b16a2 are 0BD2. How to make the swap work? Will 99-00 SI axles work in a Del sol?
Old Jan 21, 2016 | 09:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B16a2 swap into Del Sol
Yes they will.
Old Jan 22, 2016 | 09:22 AM
HondaPartsHero's Avatar
Technical Hero
Year make model. Del Sols can be OBD1 or OBD2 depending on the year.
Old Jan 29, 2016 | 05:24 PM
gmcuajo1's Avatar
If your del Sol is OBD1 just use an OBD1 ignition or viceversa. Is the same.
Make sure you use integra's rear engine "L" bracket. 99-00 civic's bracket won't work.
xx7xx
22
Nov 25, 2008 04:49 PM
EG_Warped
Feb 11, 2008 11:29 AM
nihad
13
Aug 22, 2007 07:55 AM
Axemurderer23
Apr 14, 2004 08:39 PM
mooseknuckle
Apr 3, 2002 08:27 PM
